If this picture shows it should be of a cover that I assume is a winter cover that I should remove when heating water using gas, if on mains the cover can stay on I think.
BP
BP
Beehpee said:Having just got this caravan the covers are new to me, didn't have them on the Avondale, so the covers can just be left off for water and fridge all the time unless I'm using caravan in winter?
WoodlandsCamper said:Beehpee said:Having just got this caravan the covers are new to me, didn't have them on the Avondale, so the covers can just be left off for water and fridge all the time unless I'm using caravan in winter?
Wrong
Fridge - covers OFF above 5 deg when fridge in use on gas. Also leave on during storage to keep flies out.
Water heater - cover OFF ALL the time when in use on gas. As above re flies and insects.
chrisbee1 said:Why only when on gas? Surely the electric element also needs to dissipate the same amount of heat as the gas burner .
WoodlandsCamper said:chrisbee1 said:Why only when on gas? Surely the electric element also needs to dissipate the same amount of heat as the gas burner .
The vent is to put the gas combustion fumes outside the caravan, not to dissipate heat. Therefore not used for electric only.
chrisbee1 said:You will note my reply was in reference to the fridge covers, not the water heater.
WoodlandsCamper said:chrisbee1 said:You will note my reply was in reference to the fridge covers, not the water heater.
Your reply was indeterminate and unfortunately I can't read your mind on a forum.
WoodlandsCamper said:Please re-read your reply, as I said, we are NOT mind readers. You made NO reference to the highlighted text and both clauses made reference to gas.
This is my last comment on this thread.
