Winterhoff vs Alko hitch
OK,.. at the risk of sounding thick...
If i switch from a caravan with an Alko hitch to one with a Winterhoff hitch, does it require a change to the towball? I have an Alko towball fitted but i have never heard anyone say anything about a Winterhoff towball.
No there is no need to change the towball for that change of hitch.
If it were the other way around, then yes you would need the Al-Ko extended neck ball.
Sorry Damion you are making it sound that if you fit an Alko you have to fit an extended tow ball,this is not the case if you have a detatchable or fixed swan neck.
If you have a fixed swan neck or detachable , there is nowhere to affix an Al-KO extended neck ball,,,,,speaks for itself really.
