Winterhoff vs Alko hitch
Sep 13, 2010
65
OK,.. at the risk of sounding thick...
If i switch from a caravan with an Alko hitch to one with a Winterhoff hitch, does it require a change to the towball? I have an Alko towball fitted but i have never heard anyone say anything about a Winterhoff towball.
937
No there is no need to change the towball for that change of hitch.
If it were the other way around, then yes you would need the Al-Ko extended neck ball.
930
The AlKo towball will fit a Winterhoff coupling, no problem.
You would only to change to an extended alko tow ball if it was the bolt on fixed type , a swan neck is fine
937
The Winterhoff hitch does not need an extended neck towball, only the Al-Ko does.
Sorry Damion you are making it sound that if you fit an Alko you have to fit an extended tow ball,this is not the case if you have a detatchable or fixed swan neck.
937
If you have a fixed swan neck or detachable , there is nowhere to affix an Al-KO extended neck ball,,,,,speaks for itself really.
