During the installation of my status 550, I used the template and cut a 50mm hole that was required So I got about halfway through and decided to do it from the roof instead. I had noticed I had gone through 5 wires knocking out the 12v lighting.
caravans just come back from its service they fixed it and all12v is working,all i need to do now is put mounting foot on and slide pole down with the aerial job doneParksy said:I'm sure that they'll sort it out for you and put everything right![]()
AbbeyOwner said:Sun, 10/06/2012 - 10:44am
The owner who had it before me took it off the roof and I bought another aerial,
I have booked my caravan in for a service so i will let them look at it.
AbbeyOwner said:Sun, 10/06/2012 - 11:51am
caravans just come back from its service they fixed it and all 12v is workingParksy said:I'm sure that they'll sort it out for you and put everything right![]()
I will tell you why because they are open on sundays til 4:30, so i had a quick undercarriage check and sorted the wiring out time to get a blade fuse because it blewParksy said:You must share the name of the service engineers, was it Supersonic Sids Service by any chance?
If they serviced the undercarriage are you sure that they weren't working for the RAF?![]()
