Zafiar 2.0 Dti
Oct 28, 2006
We tow a Lunar LX2000 900Kg Max 1195Kg
Like the looks of Zafira Club (2001 - 2004)
Lots of conflicting info re suitablity of Zafira.
Any advice would be appreciated.
Merry H
May 12, 2006
2,060
Hi Merry H,
If you post this under " Towcars " I'm sure you will have a response from one of the regular contributors.
Welcome by the way
Val & Frank
Oct 24, 2006
21
Hi Merry H
Try doing a Forum search with "zafira", there are a number of posts regarding its suitability as a towcar.
The Zafira is not very highly rated, you should avoid the diesel model (very low max tow weight) and the 1.6 petrol. The 1.8 petrol would do the job. Unless you really have to have one (i.e you need the extra 2 small rear seats), you would probably be better to look at something else.
MM1
Oct 16, 2006
90
Hi m8 go to www.whattowcar.com this site tells you all you need to know hope it helps.... we currently have a zafira 1.8 and have used the site to check suitability as we have purchased a new 07 bailey ranger 550/6 which we collect in jan... thanks mandy
