Škoda Kodiaq tow test
The report makes the comment that the nose load (S Value) limit is only 80kg! This is exactly in line with the EU directive on S values where the tow ball must be rated for a minimum of 25Kg or 4% of the towed weight limit which ever is larger.
4% of 2000kg towed weight limit = 80kg - Spot on EU regulations
If you ran a trailed of weight (1795kg x 85% ) = 1526kg with a nose load of 80kg that would be 5.2% nose load which is within the UK 5 to 7% guidelines.
In actual fact if the caravan had a MTPLM of 1526kg, the 80kg nose load means only 1446 is towed and that would equate to a 5.5% nose load.
So whilst the comment is correct in so far that other larger SUV's may have a greater nose load capacity, the Kodiaq should be adequate for the size of caravan.
80/1526 = 5.2%
