13 pin socket with Fog Cut Out
May 4, 2023
32
35
I need to replace 13 pin socket with fog cut out. I have had a look on line but there are so many poor Chinese fakes. Anyone suggest a good make or source. The original was made in Germany.
Oct 8, 2006
1,783
551
In many (most?) cases with ECU updating for towing, the rear fog lights on the towing vehicle <should> automatically cut out but leave those on the trailer working. You will need to check it yourself. It is not an offence in the UK (AFAIK) to have both tow and trailer rear fogs working simultaneously.
If the original socket was German it was likely by Hella - which is a good place to start.
May 15, 2023
137
118
135
I agree with Woodentop, most modern vehicle will sense a trailer / caravan is attached and sort the rear fog out , if this is some earlier system it would have require some adaptation to the towing vehicle wiring? as a break will be required? You could simply add a relay to switch the fog lamps off when towing?
Jan 20, 2023
812
681
1,135
As others state, the fog light cut-out is "downstream" from the socket, simply replacing your 13 pin socket for another won't affect this function.
