- Jun 20, 2005
- 20,158
- 5,397
- 50,935
Thanks for the update. At least you are wiser now and will take each step carefully. Damp testing with the meter is a science . Basically work methodically around the bottom sides and tops of every window.Carefully lift the rubber seal which touches the wall board and insert the prongs for a reading . This hides signs of pin prick holes and is an accurate starting point for water ingress via a failed seal. I do the corners and then the straights with two more readings, more if it is a wide window. Then do the same around the upper wall near ceiling in case the awning rails or upper window hinge seals have failed. You say you have a diagram so follow it. Basically lifting seats and testing all areas of panel joints. Where the wall board shows marks on your photo take more readings gradually expanding outwards to try and establish how far it has gone. Wet timbers can be dried but if they have rotted đ€ŹGood luck and let the brain not the heart rule the day
