2017 Vango Kalari 420
Feb 3, 2008
3,790
:silly: "The awning's draught skirt comes with mesh panels for ventilation"
Doesn't that defeat the object, or is this the way around the condensation problem in those type of awning?
4,048
Is PC trying to get people NOT to buy this awning, the pictures makes it look realy tattie, I will stick to my Swift 280. Much nicer.
4,048
WC the awning skirt has zip down panels, more weight and something else to go wrong.
Aug 23, 2009
3,167
The weight makes it totally unsuitable for Mrs B to put up on her own and what a mess it looks, and that I consider to be a major understatement. In 45 years of caravanning I have never seen in practice and we have never needed ventilation in the draught skirt. I have yet to see or hear of any air awning that I would change the Issy Magnum for.
Jul 11, 2015
482
Don't put the draught skirt on if you want/need ventilation :evil:
Must admit I don't always put the draught skirt on, nor the bit that goes over the wheel well above the skirt (probably cos I don't want to 1 drill holes for press studs 2 stick gunge for hooks/clips 3 do a Heath Robinson add on to make up for lack of forethought by caravan assemblers)
Martin, our Bradcot Aspire Air has proven to be a great bit of kit, have a look at one on site if you get the chance, particularly if as us, we don't want to look into an awning from the lounge :p
Aug 23, 2009
3,167
Our wheel cover is attached to an adhesive strip from Isabella so no drilling to do.
4,790
As I've said before the proof will manifest itself in a few years time.
Even Bailey are jumping on the bandwagon with their Prima range designed in the UK. Still using exterior guy lines :(
Jul 11, 2015
482
No guy lines on our Bradcot Aspire Air 390 :p There are storm straps supplied with sewn in connectors should they be required in stormy weather, that we used once when some Isabella full awnings came down in Cornwall in 2015
Isabella have launched an inflatable awning recently, the Pascal 390 I think it was, but called a 'Porch'. Was it reviewed on here?
1,971
The pictures are awful. Can only assume the team cba'd on inflating the cross beams as it looks very saggy across the front. Awning review after awning review on here is for an inflatable awning. All over £1k. Come on PC, review some poled awnings or budget poled awnings or even second hand awnings once in a while. Or how about reviewing awnings that can easily be put up by one person or a person with disability or physical limitations.
4,048
Mel, do you mean people of Parksy and my height?. We use the Awning skirt to try and keep the Ratter under contol prior and after a walk. . Modified one of ours with peg down holes to keep the little beast in.
1,971
..and of my height, age, woeful lack of fitness, inability to see close up without glasses, hot flushes, arthritis knees and lack of patience with badly written instructions. B)
3,167
Well from my seated position I'm littler than the lot of you at around 4'8" That's in the main chair, the little one on site and I'm even tidgier :cheer:
1,971
Yes, but if our Sprocket ever reappears he could bodge together a Scissor Jack and your chair ..................................................... :cheer:
4,790
That's my kind of Woosie :kiss:
