Adding external 12v socket
I have a Swift Sprite Alpine 2 with no external socket access either mains or 12v, and I'd really like to avoid cutting unnecessary holes in the outside.
I've added a secondary fuse box to run some usbc inserts for powering laptop and charging phone and I'd like to be able to run a small fridge outside, which will run off around 3a.
Given that all the electrical gubbins is on the same side as the battery and EHU insert and all inside a locket, I am wondering if it would be acceptable to add a 12v socket to the battery locker (note there is a separate compartment for the battery and EHU/motor mover isolator within the same locker).
Are there are pitfalls or issues I should think about?
Thanks in advance!
If you have a nearside locker it may have a cable cut out the same as the EHU and battery locker.
Mine has and I just ran a cable round under the seats and fitted a socket just inside the locker.
It's used for the awning pump also the awning lights. The locker shuts just fine on the cable due to the cut out. I didn't know it was there until by chance I looked.
If you have a nearside locker it may have a cable cut out the same as the battery locker.
No nearside locker either sadly or that would've been exactly my plan!
The other idea is to use the vents in the floor under the nearside sofa to drop a cable through and add the socket there, doing exactly what you say with running a cable round (or even under the floor as there is a channel)
How about fitting a waterproof socket into the front locker ?
I think I have a 12 volt supply socket in my battery box as you mentioned, but , as I don't use it, it might have been in the last caravan.
Interesting thought thanks, I'm a little concerned about taking electrics into the gas locker though!
Good to hear that it's been a "thing" to add to battery box - though in a way the whole point of the sealed box is rendered irrelevant as I have an LFP battery
Yes, that's a thought, the compartment for the battery is sealed from the UHU , it's a shame I didn't get a full photo of the box. 466926b.jpg
Yes, that's a thought, the compartment for the battery is sealed from the UHU , it's a shame I didn't get a full photo of the box. View attachment 10258
Yours looks almost identical to mine - same door to open the locker but separate compartments inside.
I'd need to have a look at how much space I've got around the EHU socket and the motor mover isolator but I think that's the best way. Run the cable under the caravan to the fridge/cool box and all good!
Not to the purists taste possibly but we needed an external 12 volt socket to allow charging for a mobility scooter.
I simply got a cigar lighter socket, 2 lengths of suitable wire and an inline fuse. Connected straight onto the battery and tucked away in the battery box when not needed and fed out through the EHU lead cut out slot when required.
Thanks, I'm reassured to read that! I think I may do very similar
Electrical items are NOT allowed in the gas locker , neither are cables through the vent holes , these are gas safety items and if you have the caravan serviced then the engineer will condemn the caravan. Just bite the bullet and cut a hole and fit one of these , use a multitool to cut the hole. You can always remove the 13 pin socket and fit your own connector.
