Morning all,
Just need some advice please. Looking to discover if there is a safety regulator or organisation etc for caravans. Similar to VOSA for vehicles.
Reason being, I believe someone needs to be made aware of a potential problem with the electrical installations in some caravans. I specifically know about some Coachman models but it could potentially affect any van which uses a BCA distribution board. I have approached both Coachman and BCA, both are completely ignoring me. The dealer (correctly) says it's a matter for Coachman and they won't get involved.
The specific issue is that the BCA board contains a set of mains breakers which are like those used in a domestic 240v installation. Therefore, it follows that there must be an inspection schedule for them, something BCA won't confirm. However, the installation in certain caravans is such that the cover cannot be removed without significant dismantling of the caravan (the whole offside font bench seat in my case) which means it doesn't appear as an inspection item on the maintenance regime.
The result in my case was that the incoming mains cable securing screws in the RCD worked loose causing the cables to arc and thus burn out the (cheap Chinese) RCD device. Had I not caught it in time it would most certainly have resulted in a fire, i.e had we been out for the day instead of asleep in bed when it happened we would have come back to a burnt out caravan. The smoke set off the alarm which woke us up and I pulled the hook up cable out.
If this was a domestic installation I could report it easily to the likes of NICEIC, the HSE, The Council under building regs etc. But nobody I can find seems to regulate this for caravans Any ideas please folks?
Many thanks.
Dom.
The offending article.
And as an aside, for all their boasts that Coachman make about their build quality, I personally feel that if they believe this is an acceptable standard of installation then their standards are a low lower than they claim. Diabolical is one word which comes to mind. And normally hidden with a plastic cover rather than actually doing the job properly and dressing the cables back as any competent person would. Whoever shoved all this lot in clearly has no understanding of things like inductance and capacitance.
Many thanks.
Dom.
