Alde Antifreeze versus Holts
Mar 17, 2020
533
394
11,135
Need to top-up my system with the 5 yr pink variety of Antifreeze. Checked prices on Amazon Prime and found these:
Presume both are Glycol? Certainly both are G13!
Note one significantly more expensive than the other.
Note one has a claimed effective life of double the other.
Note both are G13
Note one arrives faster than the other.
Clear winner in Holts.
What am I missing? Has anyone any thoughts on which to buy? Any dire warnings I should heed?antifreeze.jpg
I'm presuming mixing would cause no issues (currently just finished the Alde G13)
Nov 30, 2022
1,940
1,816
2,935
One things for certain, Alde dont make their own fluid, they buy it in from a supplier, repackage it, and hike the price.
You decide but I know what I would do!
Sep 23, 2023
1,332
576
2,435
Are both based on O.A.T,(organic acid technology),if so then they have a life spans of around five years,I personally use Preston's from Toolstation that lasts upto 10.years and has a wide temperature range
3,495
Check that they're both concentrated and not ready-mixed - as some fluids are already diluted at 50%.
I believe the G12++ is the latest requirement from Alde.
405
245
4,935
I buy exactly the same spec as the Alde fluid, easily sourced and decant into a 1ltr bottle from Alde that I keep in the van.
Mar 17, 2020
533
394
11,135
Both OAT so far as I can tell.
Both 50% dilute and ready for use.
The advantage of the cheaper fluid here is price. Alde lasts 5 years whilst the Holts stuff up to 10! (Mind you I would still change after 5 and ignore the apparent saving of a 10 year life)
My reason for posting was just to check forum views. I'm sure Alde don't make the antifreeze as Mr P points out and, lets be honest, anything connected with the leisure industry seems to attract a rediculous price hike!
Oh and Holts is G12++ or G13, pink in colour and matches the Alde advice regarding type of stuff to use. (G12++ or G13)
Very confident Holts will do the job and whilst both are affordable I see no reason to pay over double the price for the Alde name!
Thanks for responses.
450
372
935
The G12++ that Alde now specify is because G13 had a constituent which is now banned in Germany (2024)and as both Fuchs and BASF are based in Germany then the G13 would become unavailable, having said that you can still get G13 no problem, so either it's made elsewhere by other companies or they have changed the formulae but its still meets the specification. They now supply either G12evo or G12++, confused or what?
Reactions: RogerL
May 15, 2023
160
140
1,635
Manufacturer branded goods nearly always come with a premium, I changed a wheel bearing on my Ifor Williams trailer last year, the Ifor Williams "packaged" bearing was 3x the cost of the same bearing from Simply Bearings:astonished:
  • Wow
5,201
and both bearings came off the same line and out the same door at the manufacturer!
Reactions: Dustydog and Johnb
4,003
1,750
I ensure I buy here products that are actually "approved" by the spec holder/owner to the required specification, not that claim to "meet", or are "suitable for vehicles etc requiring the specification".
I know these statements can result in different things, and are written very carefully to be assuring to the uninformed and just keep being legal. Unfortunately unlike the product itself words as used are not copyrighted.
Some can be quite suitable, but they are not what the buyer might assume they are buying, an approved product that "will" be suitable.
Here the G12++ is a Volkswagen Audi Group specification.
A particular critical challenge, here and with antifreezes in general is not in achieving protection from freezing but in their longevity and application related safety, along with no unwanted complications. of control of corrosion protection. Alde having identified what products meet their equipment's needs.
Reactions: Martin_E
4,003
1,750
However, as most equipment makers don't publish who their actual OEM, item maker is, then having that little gem of info is very difficult to find out, other than if it's blazoned on the bit you removed etc. In the quoted rolling element bearing case with many counterfeit and unknown brands about I would be very wary. Much as there is with antifreezes, a huge market out there for budget products.
5,201
Not really as in many cases the container looks exactly the same as the original one.
Mar 17, 2020
533
394
11,135
Of course that's perfectly true - no argument there. It's unlikely the OEM maker can be identified in most cases.
However it would be nice to compare the volume of Alde branded antifreeze sold (no matteer who actually produced it), with the volume of a repultable company like Holts. Not heard of any court cases where antefreeze has been sold that doesn't mach a claimed specification!
We are not talking of a comparison between Alde branded antifreeze and a budget product from a tiny "back street" manufacturer. It's not that Holts produce "budget poor quality products" rather that Alde re-brand a similar product (could even be the same one!) and hike up the price for vulnerable caravan owners.
You pays your money and takes your choice. Mine was Holts.
450
372
935
Bulk users can ask the manufacturer to 'bottle the products with their own labels. It quite normal in manufacturing ,I found this out when doing a bit contracting at Cotts . Their customers even had their own livered 40 tonners to collect the bottles.
Re Alde branded fluid , some customers and engineers want the confidence that they have used the 'correct' fluid , its their choice , same for Alko brake linings and hubs e.t.c. The funniest one I witnessed about the 'correct part' was after the Challenger disaster , at the televised congressional hearings, a Senator asked about the rubber mallet used to position the O rings into the booster sections . For every booster rocket Morton Thiokol supplied a rubber mallet wa supplied to Nasa at a cost of approx $1000 ( don't quote me on that it was a long time ago), The Senator queried the cost as he could go to Sears and buy the same Mallet for $10. The man from Morton Thiokol answered quite calmly yes, but the ones they supplied to NASA were 'calibrated'. It has always stuck in my mind is:- how exactly do you calibrate a rubber mallet?
2,565
As we are new at this gone for the Alde Premium G13 Antifreeze brought it from a caravan dealer near to our site but it your choice what you prefer .
5,201
Whatever you do, make sure that you do not over fill. Stick to the minimum line to be safe.
