Different to my AWS - but I'll take Alde advice over his.Here we are with Alde’s advice. The level should be 1cm above the minimum mark when the system is cold.
FAQ - Alde
www.alde.co.uk
FAQ - Alde
www.alde.co.uk
it says about 1cm above min line when cool but I let the caravan engineer sort it for me 🙏BB isn’t there an Owners Manual for your Alde system, I’m sure that like my ones for the cars it would tell you where to fill the system level to.
Well make sure he sets it at the correct level as recommended by ALDE as some on here have been given conflicting advice by their engineers.it says about 1cm above min line when cool but I let the caravan engineer sort it for me 🙏
When hot or cold?
When coldHot or cold? It makes a difference.
Hi clive that not the only thing, i want the gas engineer to look at the radiators they are hot at the bottom but cold at the top so I think there trapped air so I think he have to bleed the system thanks for your help in this matterWell make sure he sets it at the correct level as recommended by ALDE as some on here have been given conflicting advice by their engineers.
Bleeding is quite easy just like you do at home. After bleeding don’t forget to check the fluid level and top up as required.Hi clive that not the only thing, i want the gas engineer to look at the radiators they are hot at the bottom but cold at the top so I think there trapped air so I think he have to bleed the system thanks for your help in this matter
What is a simple task to some people, is not easy for others.Bleeding is quite easy just like you do at home. After bleeding don’t forget to check the fluid level and top up as required.
Identifying where all of them are located I found quite a challenge, adding to this access needed some disassembling of the furniture, admittedly that was doable.What is a simple task to some people, is not easy for others.
