When we where at the N.E.C. show in November we visited the Al-co stand to get some information about the Al-co ATC. My wife entered the competion to win one. We had a phone call about a fortnight ago saying we were one of twenty five winners, just waiting to have it fitted at their factory in Southam, Warwickshire.The only problem we have is that while on holiday at Dornafield somebody reversed into our caravan with a towbar ahd put a hole straight through the rear bathroom (Spectrum 540) . Going to cost about 3k to fix.In reply to earlier comments on the lines of do you really need the extra kit, i have to say yes.
We have been vanning for over 25years and have never had a snake. I am very careful in the loading of the van and check the noseweight.
A couple of years ago we were on our way for the weekend and driving along adual carriageway at 60mph.
As we came to a slip road a car was coming to join the lane I was in, I had a car coming up in the outside lane so could not move out to let him in.
Usually when cars see a van like this they either accelerate away or slow down to let you get ahead.
This one just pulled across towards me. I swerved to avoid him and set up the most horrendous snake.
So with the van loaded and driven correctly I experienced a snake - I just wish I had ATC then.
Is it me or is a chunk of the original message/question missing?
In my humble opinion this should be MANDATORY on all new caravans!Hi Has anyone had any experience with this system? Is it an advantage to have when towing & does it work? My interest is due to it being an option on the new van we're considering buying & apparently it only takes 15mins to fit at the new assembly stage. Comments would be welcome please.
I would class that as an electrical failure. But I know what you mean😁In my humble opinion this should be MANDATORY on all new caravans!
We have it, saved my bacon on one occasion which was one too much, without it car and caravan would have been toast, (note second breakfast reference 😋)
Its a fabulous system but like all things mechanical it can fail, I found out that a flat caravan battery renders the ATC inoperative. 2016 Coachman Pastiche
Doesn't the ATC use the 12v from he car battery and not the caravan battery?In my humble opinion this should be MANDATORY on all new caravans!
Exactly what I thought, but I found out first tow last year that it (on my caravan) doesn't.Doesn't the ATC use the 12v from he car battery and not the caravan battery?
I guess there is the possibility that the caravan battery which takes charge from the car dragged down the 12v? I am not a fundi on car electrics. 😀Exactly what I thought, but I found out first tow last year that it (on my caravan) doesn't.
The caravan battery was dead flat as the motor mover didn't!
Nipped down Halfords, 10% AA discount, put on a new leasure battery, ATC worked straight up, so ATC power is definitely integrated into my caravan.
possibly.I guess there is the possibility that the caravan battery which takes charge from the car dragged down the 12v? I am not a fundi on car electrics. 😀
So for anyone reading or simply for the memory bank of ATC faults maybe the quick get out of jail FIX to get home would have been to disconnect the caravan battery?From my understanding the ATC is powered by the sustained 12 V supply from the car, the one that also charges the van's battery when the fridge supply switches the habitation relay.
So if you plug the caravan in without the car engine running the ATC is not connected to the van's battery,
When you start the car, then both the ATC and the van's battery charging are sharing the car's battery feed.
With a "dead brick" of a van battery sapping everything it can draw, I would expect little is left for the ATC, the current and resistance pulling the volts way down. I think your findings can be explained by that configuration, It should be remembered not all caravans come with batteries, nor is one required for the ATC to function, however it is understandable a duff one could screw the ATC up.
If using the 13 pin coupling, this permanent feed has its +ve on pin 9, its -ve on pin 13.
The fridge and habitation relay are powered via, pin 10 +ve, pin 11 -ve.
Edit: I note you are now saying the ATC did not work even with the car engine stopped, strong indications here something else is wrong with your system, habitation relay?
If you have such a device and find it is operating frequently, then you should be looking for the reason its operating and removing the cause, whether that's changing your loading strategy, or driving more carefully, prevention is better than cure.
We had a very bad snake prior to caravans having ATC. I took my foot off accelerator to slow down the car, then gently accelerated again which pulled the outfit straight. Later pulled over to change underpants!The one and only time my ATC kicked in the outfit had started to snake🐍.
The caravan applied the brakes once briefly, the outfit continued to snake, then the ATC locked both caravan wheels which did the trick.
Interesting experience, we had travelled around 125 motorway miles when it happened and travelled a further 240 miles without changing a thing after!
I did pull into the next services to check things over weight wise etc, but found nothing wrong.
For those with a wish to consider and understand their ATC better;
Prof that is an interesting comment with which I fully agree with its underlying message, but the ATC is a relatively dumb system, not taking all factors into account so can intervene when there is no danger.
Understanding this can be beneficial in so far as noting its intervention can be confidence assuring, its intervention does not always require seeking a cure, as your comment might be taken to imply.
It detects swaying motions, such motions that, if encountered under some conditions can preempt an uncontrolled snake. However, such motion can naturally occur where the van speed is so low things will not go wrong.
One case that occurs, where it intervenes is the rolling of the van as you creep over a bumpy rally field, or even travel obliquely over a sleeping policeman. Another is the switchback motion tracking round and out of a tight roundabout, the common feature though is at very low speed.
Here, the very swaying the ATC is designed to detect is there and it intervenes, though the other factor, kinetic energy from "speed" is not there, so a snake can't develop, nor of course can the ATC take its speed killing action, its only tool to abate the snake.
Understanding, that you will note the ATC dabbing the brakes under these low energy conditions is IMO a healthy "tool" we have, knowing it is functioning as designed, the more so as we really have no other way of knowing its sensing electronics has not failed.
