Alko spare wheel carriers
Oct 20, 2022
90
36
1,585
Can I suggest if you have one of these is to check it out regularly to make sure the sliders are free.
After coming home and put caravan on drive.,next morning there was a flat tyre,to make matters worse our drive is a downward slope.Spare wheel carrier seized up,had to take everything off.Lashed car to van to act as a brake and managed to put spare on.spent last 2 days renovating carrier.2 new tyres put on as they are 5 yrs old,tomorrow will put back on carrier.if anyone wants info how I repaired the sliders just let me know and I will put on site
3,977
Sorry to hear about your problems, I think you will find many caravanners have removed the Alko wheel carrier and stowed it in sheds or garages. On my last two Coachman vans the spare wheel is under the fixed bed. Removed the carrier. A saving of 6.5 kg. If your touring Europe, changing a wheel and trying to remove that AlKo carrier is a NoNo.
2,351
11,935
I kept the carrier although I did not like it. but it was greased as part of the yearly service and tyre check.
3,977
Ah, that's another point, when the carrier and wheel are clamped up the carrier wears on the tyre.
3,814
1,543
It can be a big help to tow the flat or even both wheels up onto some wooden blocks to gain more access space; still needs you to maintain the carrier so it will slide as it is designed to, properly,
Still not one of the better bits on caravan chassis design IMO.
8,139
I used my levelling ramps to raise the unit higher, but the Alko carrier was removed in 2006 when I first had a van fitted with it. Prior to that spare wheels were in the front locker.
4,654
Surely when they service the caravan they should be checking the spare wheel which means removing the carrier?
2,953
I'ver never known the spare wheel be "serviced" by a dealer or mobile AWS technician - I guess if you specify it they'll do it at extra cost.
4,654
It should be included as it should be part of the "running gear"?
8,139
Your AWS schedule should say if the spare wheel and carrier are checked or serviced by inflating the tyre and/or greasing the carrier.
2,381
We removed our Alko carrier and put it in the garage and there was room in our caravan front locker and the spare wheel went there it was easier access for my mobility issues
Reactions: Bluetonic
4,654
I agree as I would have thought that they would check the pressure of the spare tyre and to do that you need to remove it. Although we have an ALKO hitch & axles etc I have a feeling that we have a BPW chassis as the spare wheel carrier is a drop down and very easy to access.
Sam Vimes
2,261
1,787
My service was done yesterday. The checklist shows that the carrier and condition of the tyre where checked. The report listed the tyre manufacturing date, pressure and tread depth.
Whether or the spare was removed I can't say - maybe its possible if the van is on a hoist it could be checked from underneath.
4,654
Wouldn't they need to check both sides of the tyre?
2,351
11,935
I have assumed that the carrier and spare was serviced when a dealer has done the service. (But who knows). But both mobile techs I have used, have done it without being prompted.
607
413
5,135
I removed the Alko spare carrier on our 'van.
Saved about 15kg on the payload. Now lives strapped down under the bed so no scrabbling around on a wet floor at the side of a busy motorway when needed
607
413
5,135
After picking up my mum's car following a service at the main stealers and discovering they had forgotten to put any oil in the car, I don't assume anything other than they will have wiped a silicone soaked rag over the engine cover
Reactions: Jcloughie
Sam Vimes
2,261
1,787
It was certainly on the checklist the dealer had of things to do.
