- Mar 5, 2010
- 2
- 0
- 0
I have just purchased new alloys for my explore 474 caravan, my question is: can I use the wheel nuts from my steel wheels
thanks guys for all your comments - it seems i need to contact the wheel manufacturerSee below an extract from A{pipe delimiter}l-ko's website.
Damian is absolutely correct!
ATTENTION
Some manufacturers are now being offered aluminium wheel rims as an option on many new caravan models. As there could be differences in installation requirements for steel and aluminium wheel rims, it is important to confirm fitment requirements with supplier/manufacturer of the wheel.
The standard M12 wheelbolt supplied by AL-KO (Our Part No. 2081670018) has a 60o conical seating arrangement and can be torqued to a MAXIMUM of 88 Nm (65 lb/ft).
If the seating in the wheel to be fitted differs from this or a higher torque value is required then an alternative wheelbolt will be required. This would normally have to be sourced through the wheel supplier as there is no alternative in the AL-KO range.
Dustydog
Unless you carry a set of suitable boltsIF alloy wheels need different wheel nuts/ bolts to steel wheels - someone needs to tell the motor industry - they simply ensure that alloy/steel specifications are the same and use the same torque setting.
If a caravan manufacturer fits straight-taper steel wheels and spherical taper alloys, or vice-versa, it's an unsafe practice.
If caravan alloys need different nuts/bolts to steel - you'd better not have a steel spare!
They leave them on the van see my reply below(regards)If you have alloy wheels and the correct bolts then these can happily be used on steel wheels. You just do not tighten them so much. However, bolts designed for steel wheels cannot be used on alloys as the grade of steel is different and cannot take the higher torque.
Again, it would be sensible for all bolts to be made suitable for both alloys and steel wheels, but again ALKO seem to try and reduce the options available to their customers. They know full well that many manufacturers supply alloy wheels as standard but instead of listing a specification that should be followed, sidestep the issue.
One does wonder what the manufacturers do with all the spare steel wheels and tyres they 'inherit' with the chassis from ALKO.
It is very bad practice. The wheel location and much of the load carrying is on the taper contact area, all the fluctuating rolling load once the contact relaxes. Its not as if loose wheels is unheard of on caravans even with the designed taper contact?JTQ, whilst I appreciate your comment, it is not as bad as you are trying to make out.
If you have no other option in an emergency situation and do not have two sets of bolts, then using the bolts for alloy wheels will get you out of a situation.
I do NOT mean driving at the max speed, but taken carefully it will not present a problem.
I have, and know of many others who have, had to do this at one time or another and it has not been an issue, and the bolts were fine, the wheel did not fall off, and no damage was done to the steel wheel.
Now we are in agreementOh to live in a perfect world !
I have a German van, and very nice it is.
But, they dont get everything right all of the time.
