Any painters n decorators out there?
I want to emulsion a wall with a bold colour but how do I get a clean straight line against the white ceiling?
Help or ideas gratefully received .
A good quality brush, patience, and a steady hand.
The old fashioned way.
If you are not confident with that then pop along to your local DIY store and have a look around, there are various types of tools available, from square paint pads to straight edges.Also never done it but masking tape may be an option. Hope this helps.
One approach would be to use coving. If that's not an option first of all paint the ceiling ( 2 Coats of best quality paint)
It doesn't matter if the walls are smudged or overcut as long as the ceiling paint goes in 'solid' ( Use Matt emulsion)
Next, stir the darker emulsion, decant a small amount to a paint kettle (buy them in Wilkinson's - plastic will do) and choose a good quality paintbrush which should be at least 2.5 inches wide if not more.
Get your steps into position when the ceiling has dried out and practice using the brush without any paint on it first of all. Decide which hand is going to do the painting, the brush should be roughly at a 45 degree angle between wall and ceiling.
When you feel comfortable load your brush with emulsion from the kettle, wipe off any excess one one side of the paint kettle.
Start away from the corners and rest your hand so that you paint a steady line with the edge of the bristles, cutting in to the white ceiling.
Continue cutting in along your line painting up to the finished surface (the white ceiling)
It doesn't matter if paint goes onto your hand, it will wash off and dont worry too much if you stray over your chosen line because you can always dab a bit of white emulsion on later to cover any mistakes.
Take your time, work up to corners using the end bristles and you should achieve satisfactory results.
If all of this fails - get a painter!
Hi Anne
Good advice here.
I always use Dulux Trade paints available from any good decorators trade shop, not your Homebase or B&Q. You don't need a Trade caerd these days. All they want is your money.
The paint , in most cases is no dearer than a "domestic " Dulux.
It is easier to apply, less runny, lasts longer and has a superior opacity.
Dustydog
