- Feb 2, 2024
- 170
- 30
- 1,585
Hi All ,does anyone know of the best accessory/fixing to use to fix the upright awning poles to the caravan and if so from where?
yes to get the upright poles closer to the vanDo you mean the poles to seal the ends of a "Porch" awning , or bigger. To the sides of the caravan. ?
What make and model? Isabella for example use a different method from others ?yes to get the upright poles closer to the van
It will be difficult. The uprights which run top to bottom have to anchor somewhere at the the top of the awning or its upper rail. Does yours?At ground level,I merely put a peg into the ground under the caravan , attach a flexible guy line which pulls the bottom of the upright towards the lower caravan side. On the Izzy the upright attaches directly to the roof rail . It can again be adjusted to force the upright tight to the caravan side. Hope this helpsleisurewize
My Dorema porch awning had poles close to the van. Each one fixed into a corner joint and between the two corner joints was the rear horizontal adjustable roof pole. The two vertical rear corner poles had no other method of attachment to get them close to the caravan. The two rear poles also had to butt up to a vertical foam filled cushioned section that abutted the caravan sidewall. It was this that stopped draughts and prevented the ingress of rain.yes to get the upright poles closer to the van
i think i will try a flexy guy rope and thanks for adviceMy Dorema porch awning had poles close to the van. Each one fixed into a corner joint and between the two corner joints was the rear horizontal adjustable roof pole. The two vertical rear corner poles had no other method of attachment to get them close to the caravan. The two rear poles also had to butt up to a vertical foam filled cushioned section that abutted the caravan sidewall. It was this that stopped draughts and prevented the ingress of rain.
The vertical rear poles did not move once in position as the top was constrained by the roof corner pieces and the bottom had a short spike which went into the ground and being adjustable the tension in the vertical poles prevented them moving away from the caravan.
yes seen these will do more investigating,problem is the skin of caravan is bubble effect and not sure if the suction cups would grip...thanksHave you considered the Kampa Limpet system to fix the awning to the caravan wall to eliminate draughts?
The design of my caravan means that the awning covers part of the front nearside window so, an upright pole was never an option. I initially bought the Kampa Limpets along with the hole punch so I could position suction cups above and below the window. There are cheaper alternatives to the Limpets available that work just as well.
Sorry, I very much doubt they will work on anything but a smooth surface.yes seen these will do more investigating,problem is the skin of caravan is bubble effect and not sure if the suction cups would grip...thanks
