Bailey Pageant 2006 water pipe fittings?
Nov 25, 2025
Hello, I have an older pageant but am struggling with the water pipes. I need to cut one and add a T-piece in but everything I find online is showing the 12mm John guest fittings. Mine seem to be the older style where the pipe pushes over the fitting and uses a jubilee clip to secure it.
Hoping someone knows what these fittings are called or where I can order some from? Not sure if I can get a connector to convert to John guest? Only need a tiny T-piece to come off the hot water pipe. Thanks a lot
Oct 8, 2006
2,063
731
Pageant is a range of vans. It would help to know which Pageant model and which series. For instance we used to have a Pageant Majestic Series 5.
Oct 8, 2006
2,063
731
it’s a Bailey pageant series 5, thanks. Sorry quite new to caravan’s
Sorry, but you still don't get it. Pageant is a series of vans all of which have a name. For example Bailey to a range called Unicorn, but each of those has a name within the Unicorn series, such as Madrid, Seville, Valencia. Your Pageant will also have a sub-name - ours was Majestic so was known as a Bailey Pageant Majestic Series 5.
So what Pageant model is yours? It should be on the side panel towards the rear and have the name of a French area such as Provence, Bordeaux, etc.
554
456
1,135
@Tom199922 have you measured the ID of the hoses ? the link birdman sent is good , the adapters come in a range of sizes so you need to check , the last Bailey I did with these type of hoses , the ID was 10mm.
