Bailey senator indiana
Oct 29, 2022
12
We are new to touring and wanted to know what waste pipe do we need? For tge sink and shower waste pipe? Is it 32mm? Do I need any other fittings? A y piece? I'm not sure if theres 2holes or one as its not delivered yet and the seller ain't responded yet? Any clues or pictures please? Many thanks 😊
Oct 8, 2006
2,041
720
Note that the plumbing pipe is 34mm - pipe is measured by external diameter - with suitable fittings to go with it. You can buy pipe in 2m single lengths from Toolstation quite cheaply - they also stock the bends etc.
Oct 29, 2022
12
Would this be OK or too small?
9,079
That will fit the outlets on the caravan. What Woodentop was referring to was if you plan to make up something from white upvc plumbing fittings. If you look at the Amazon link that I posted go down to the picture that shows av2 into 1 plumbing fitting used for waste. Drill down on that one and you get three pictures one of which shows the internal and external pipe dimensions for the UPVC and corrugated flexible pipe.
Here it is:
Oct 29, 2022
12
Here it is:
Thanks much!
Oct 8, 2006
2,041
720
Agree with Hutch, but there is no need to go to the expense of flexi-pipe to connect the white pipe to the caravan outlets - the white pipe is an exact fit to most as well. Also check on the fittings - most take grey 28.5mm pipe, there is also grey 25mm pipe which looks very similar. The Towsure web site is one of the best places to go digging - they don't sell caravans!
Jan 19, 2002
1,705
546
You will find the item as in you #5 is commonly used - I have created a near right angle in my outlet pipe by immersing in boiling water so it sits conveniently into the top hole of the wastemaster. also carry a 3 metres length to fit instead of this on a serviced pitch
