Hi All,
A cautionary tale for those with this van. We are in the middle of our hols in Norfolk and usually sleep with the two single beds. We have had to keep on top of many loose screws in the van, principally the seat backs, I know there has been much previous on this item, the washroom door framing and I have had to add additional fixing points to the bed box sections where the flexing of the van floor causes them to work loose. But we have just had a far more serious event when making up the beds as normal, upon laying down, one end of the bed sank completely. The spring hinge had pulled out its three screws altogether and the unit collapsed. After a temporary repar that night I found the following the next morning. The hinge has four securing holes, only three screws were in each of the four hinges in total. The screws are about 3/8 '' long, which is far too short and with use the wood where the hinge screws into has become worn with the screws holes elongated so that the oroginal screws will no longer tighten. being away from home the only solution was to obtain longer screws and to fit thrm into all four hinge bracket holes. I just hope that owners check their own screws to avoid the situation I found myself in.
