Bailey Water pump
Hi All
Could anyone suggest a way to dampen down the noise from the onboard water pump fitted to my Series 6 Pageant. It sounds like a diesel engin when running, and if parked close to another van (which hasn't happend yet)I'me sure it would be heard by the other occupants.
I wondered if wrapping some sort of foam around the pump would be acceptable?
Jeff
That sounds a lot louder than the pump in our Senator
I have removed the screws that hold the pump down and previously when using a Shurflow pump for many years (that was louder) I had it resting on a car wash sponge.
If the suction hose from the aquroll is not pushed firmly enough into the socket on the outside of the caravan the pump draws air and is much noisier. Also it is much quieter when listened to outside.
That's interesting and something I have not been aware of as we always draw water from the onboard tank.
In fact we were only remarking on how quiet the pump was last tome out.
Hi Jeff,
We to have a Pageant S6 and the pump is driving us nuts, sounds like a Briggs and Stratton at full pelt. It has now got to the stage where its going back to a dealer to sort out.
Rob
Have checked system and no leaks, Inlet correctly fitted and system bled till the taps were fed up of water being drawn through.
