Why do you want to change it? The 276 is nominally rated 20A but the original (Chinese) label on it shows it to be 24A. It does however have only a single output whereas the 306 has two - it having a defined charger in it - which means it will need wiring modifications.
Float charging as handled by the 276 (as used in Baileys for at least a decade or two) is a perfectly sound and well tried process.
You could of course instead consider fitting a solar panel on the roof which will provide additional boost.
