Good Question, Simple answer, I am cutting out the 12v socket to instal an RJ45 socket and dont want to scrap something i pay £40 - £50 for. Thats why i am asking the community.Why do you want second hand when on EBay used is only £3 cheaper than a brand new one
Hi, thanks for the reply.Yes, I have the F‑connectors.The Belling-Lee (i.e. TV) aerial socket is just a panel mounted F-type adapter. All you need is a F-type outlet bulkhead jack-jack i.e that has a F-type socket on both ends and replace the existing.Thanks for your responce. I an running eithernet cables
I have to ask:My project is: I am running Ethernet in the caravan, and I need to fit an RJ45 panel‑mount socket as well.
If you only have one thing to connect.Why Not! Cable is much better. simple.
The router i have for caravan is a 4 port router. We have two tv's and my business laptop. No need for a switch at moment.If you only have one thing to connect.
Otherwise it means adding a network switch and network adapters for things like Firesticks and Roku. Which adds complication.
Says the man with 4 network switches in his house and two Roku plus a fire stick all with adapters on them.
