Aren’t the TPMS warning thresholds set so that a slowly deflating tyre will trigger a warning before it becomes a hazard to itself.
In our case, now with an old Tyrepal TB99, the setting suggested for a low pressure alret warning is, to quote
"15% below recommended pressure "
Therefore, the recommended, well the cold static value, in our case is 65 psi, the suggested Tyrepal alert would come in at 55psi.
To me, this is absolutely nuts, any value that is below the tyre makers recommended, I want to know about and make decisions on.
In use a tyre must get warm relative to the ambient, so anything below is not right.
If we don't follow the tyre makers given values reacting to changing ambient, and say have the value right only on a 10C day, though couple the van up on a -5C day, then there will be initially a sub recommended pressure.
I tend to be able to twig this, so I don't generally alter the inflation to reflect ambient changes when I tow, they are at 65 psi on a 10C type day. Basically, I only now tow in a pleasurable caravanning ambient!
I most definitely want to be aware if towing they are ever below that, most definitely long before they drop to 55 psi.
Also, if underinflated, that does tend to be self-correcting in the tyre "works" hard and the walls plus air heat up, disguising on a pressure only basis, the drama the tyre carcass is enduring.
Here the temperature warning might help, but looked at logically, the stem fitted sensors I have are quite remote from the tyre wall, and as the wheel rotates centrifual induced air flow is pulling ambient air over the sensor and rim, little chance it knowing anything about the abuse temperature of the wall, IMO.
So, I have my low warning just below 65 psi; that never goes off and I am pretty sure I am running my tyres as their maker's intended inflation pressure. Thats presently Goodyear, and I feel happy they know what is right, rather than tolerating running 15% below that value as Tyrepal suggest as the threshold of an alert evelope.
