BMW 3 series estate Plug in hybrid: towing performance
Jan 15, 2026
5
Does anyone tow or know anyone who tows with this BMW or Mercedes C300e estate? I'm interested in a hybrid because we have a charger at home, but on researching these 2 cars, found out that the manufacturers de-tune the 2.0L engine on the hybrids. So how well do these cars tow when the electric motor isn't working and just the de-tuned engine is pulling the caravan and heavy car? I currently have a BMW X1 petrol and Swift Aventura caravan 1462kg, but am up for a change of towcar soon.
May 30, 2024
126
155
635
I tow with a BMW 330e X drive touring. I am more than delighted by its performance and economy, both solo and towing. Coming from a BMW X1, you'll be very impressed with both. I also pull a Swift Aventura van, though mine's an A4, a bit lighter than yours.
I've read those things about degraded performance when the battery's discharged, but in real life struggle to encounter circumstances when it actually happens. Even when the battery display says 'zero' there is always enough for the electric motor to contribute its share of full power acceleration up to 90mph or so. Which seems enough, since once its up to speed there's plenty of spare power to recharge the battery. Anyway, when towing I usually keep it in Sport mode which ensures that there's always enough battery charge to get you to the top of an Alpine Pass whilst towing. :giggle:
What I would massively recommend, if you're buying a new or nearly new car (applies to everything, not just BMW), is that you absolutely hold out for one with an original BMW factory installed towbar. It's electrically deployable, which is nice, but these days the main issue is integration with vehicle control software and electronics and I don't believe any aftermarket installer is able to achieve that now.
9,494
Your comments mirror those of others on the Forum who have experience of towing with PHEV. Even if a motor is slightly detuned, how often is max power really needed on a modern car, and as you confirm the electric support doesn’t disappear completely.
Reactions: ProfJohnL
May 18, 2006
595
19
18,885
I agree the BMW 330e is an excellent towcar. I personally would not get one with a BMW retractable towbar. Mine failed and it cost almost 1K to replace. 18 months later that one failed as well. Cost me £800 to have it removed and decoded from the car before an aftermarket one was fitted, then another £800 to have a non BMW bar fitted.
My current BMW is a 2022 car and I had an aftermarket towbar fitted with dedicated electrics and everything works perfectly - even the fridge on the van when towing, which is something that a factory fitted BMW towbar often doesn't have.
My brothers BMW also had a factory fitted towbar and it failed last year!
2,772
Where these failures electrical or physical.
595
19
18,885
Physical. Apparently there is are nylon cogs as part of the mechanism and they can wear and strip so the bar stick either retracted or extended.
Reactions: Jcloughie
Jan 15, 2026
5
Thanks for that Andrew, it's reassuring to know so is your a diesel or petrol? I'm probably going to go for a petrol one in today's market.
May 30, 2024
126
155
635
Eeek! I'll keep my fingers crossed, then, since I'm out of warranty now.
4,462
In the last century, caravans were towed successfully by many cars who's BHP were less than 60. And even in those days the advice was to have 40BHP per Ton. In practice you do not need the prodigious power outputs of modern cars. It may be clever, and sometimes fun when on a track day, but the reality is you don't need sub 10 sec 0 to 60 in normal UK driving.
I am confident that as long as the caravan does weigh more than the cars permitted maximum towed weight the any car should be capable of towing. It may not match your expecations in which case you have the wrong expectations.
May 30, 2024
126
155
635
In terms of power, I entirely agree that modern cars usually have plenty. As always, you have expressed a technical and legal best practice answer to a question posed (well, assuming that you meant to write '..as long as the caravan does not weigh more than the cars permitted maximum towed weight..').
But there are some nuances and preferences, admittedly already fought over in quite a few other threads, but which I think are helpful to someone thinking about what towing vehicle to buy. Not just the specified and permitted maximum towed weight.
For towing, the torque characteristic of the motor is important; traditionally caravanners have liked diesel engines for their lowdown torque. Modern petrol engines can also be good (or terrible). If when you're driving it solo it feels gutless as you set off from the traffic lights or when you try to be brisk about pulling out from a junction, you're going to feel that much worse pulling a caravan as well. The characteristic of electric motors is also very good, just the range and public charging that worries people about towing. My opinion is that plug-in hybrid (PHEV) is great for towing and the best I've experienced.
Then also quite a big deal is the type of transmission - manual gearbox, torque convertor auto, dual clutch auto and these days a multitude of other novel arrangements. Traditionally, most caravanners have favoured automatic transmissions. However, these days most automatics are the dual clutch type and I harbour quite a dislike for those. Others may (and will!) disagree, but they can be jerky and notchy in low speed manoeuvring and the software can be slow to react when you need to join a gap in traffic. All a bit unpleasant and although it feels like you're driving an automatic its all a result of computer controlled slipping clutches. The thought of towing with a slipping clutch makes me wince. Having test driven a few different options, I came down quite firmly on my choice of the BMW 330e because they still use a torque convertor auto.
5,477
Makes you wonder why a hybrid car with a 2.5ltr petrol engine can only legally tow a maximum of 1500kg when it could probably tow a lot more as kerb weight is a lot higher than 1500kg?
9,494
Fully agree your comments wrt dual clutch auto boxes. I’ve had two. One DSG on a 2 litre Superb diesel and one on a Kia 1.5 turbo petrol Kia Xceed. Both cars drove very well under normal driving conditions, but were not good under very slow manoeuvring such as close parking etc. The Superb with its diesel torque and conventional handbrake being somewhat more forgiving than the Kia Xceed with electronic handbrake. Other than conventional manual or torque converter autos I’ve had two Subaru Forester petrols with CVT gearboxes. No issues whatsoever and very smooth throughout the complete range whether solo or towing. The XT being brilliant all round car, but quite a thirsty beast.
We decided to sell the Kia because my wife wanted a higher riding car and we acquired another dog and the Kia was a bit short on space. So looking around we plumbed for a Toyota RAV4 hybrid, and it’s close in manoeuvring is inch perfect and it’s just seamless between petrol and electric drive. All I do is turn off auto hold when close parking etc. With a 4 cylinder 2.5 petrol giving 160kw and front motor at 88kw (215 bhp in total) overall its remarkably economical, but it wasn’t bought to be the last word in economy, but for its 10 year warranty and space.
