I currently run my caravan with blue BUTANE bottles,am i also able to use orange LPG bottles, also are their any different issues between the two.Roll on the new season weekends are so boring.
It would not let me transcribe the full article.Petroleum hydrocarbon structures
Petroleum consists of three main hydrocarbon groups:
Paraffins
These consist of straight or branched carbon rings saturated with hydrogen atoms, the simplest of which is methane (CH4) the main ingredient of natural gas. Others in this group include ethane (C2H6), and propane (C3H8).
Scotch lad for you
Hydrocarbons
With very few carbon atoms (C1 to C4) are light in density and are gases under normal atmospheric pressure. Chemically paraffins are very stable compounds.
A BASIC LESSON IN ORGANIC CHEMISTRY.... No, the info is NOT right.. Butane has four carbon atoms as stated but propane has three carbon atoms, not five. The molecule that has five carbon atoms in the same configuartion is called pentane.The reason butane is still used widely is that it produces more calorific heat per unit than propane, it has 4 carbons in the chemical structure whereas propane has 5, so if you
Are you sure this is correct ??
Val & frank
