Cadac from caravan
Oct 24, 2024
108
61
135
Hi. My caravan has an outside gas point which we are going to use. I've purchased the connector to click in, but do I need a regulator in-between the caravan and the cadac, or is that built in to the van?
Thanks 👍
5,307
Thanks 👍
My external gas BBQ point uses gas that has passed through the regulator mounted on the bulkhead next to the cylinders. Can you see your gas cylinders and the regulator?
What make and model?
Oct 24, 2024
108
61
135
Ah. Yes, I now see a regulator in the gas locker.
So I presume as that's inline between the gas bottle and the outside gas point (albeit about 3 meters away), all will be well?
Bailey Unicorn Cadiz, and thanks for a speedy reply 🙏
5,307
Yes.Enjoy.
Reactions: CrewOVtwo
4,526
As you have found the routing of the gas pipe from the regulator to the gas point, you can now see you don't require an extra regulator
Enjoy your Cadac. .
Apr 13, 2021
188
141
4,635
I have used a cadac from the external point for years with push connectors
I have 2 different lengths of pipe to suit where I position the cadac
2,571
That going to be a new experience of trying a cadac from external point on our latest buy
4,526
Have you never used a gas BBQ from your caravans?
My friend gave me his old Cadac 2, told me it was beyond repair, I took it apart, tightened up the gas valve, and fitted a new Pieso ignitor, £6.98 eBay. I now have two cadacs, and 5 different cooking grills.
