xtrailman said:
Sproket thanks for the link, I have seen that item and considered buying from them, in fact I think I will.
most suppliers are out of stock I wonder if a updated version is due?
I think that a new version is already out, with better night images apparently.
Re the overheating - I've read about it, but not experienced any problems (although the 0803 does get hot)
I like it because it's small enough to leave in-situ without being unduly noticeable by passing scrotes. I know that if I had to connect it up every time, I'd just end up not bothering to use it. As it is, it's 'fit & forget'
I should also mention that the 0803 (and hopefully the replacement) has a very good dynamic range - it's hard to blow out highlights. The Aptina sensor was one reason I chose it. The new one doesn't use an Aptina CMOS
Sample image: (resized for upload)
