Hi all, The tyre pressure for my car says 2.2 bar but even at that they still look a bit low, Should i put extra air in the rear when towing ?, any thoughts please.
Craigyoung said:Ours is a 7 seater and I put 36 psi in mine on 16" rims
Dustydog said:What I do know is all Japanese imports , grey or otherwise, have the tyre pressures detailed on a sticker on the the drivers door frame . Do you have this?
ProfJohnL said:I cannot recommend over inflating just to make a tyre look right.
Tyres are the vehicles only contact with terra firma. Given their importance, tyre pressures should not be judged by eye, you should measure them and set them correctly.
Vehicle manufactures do not just throw any old tyre onto vehicles they will choose the size and rating with some considerable care, and they will determine the recommended pressures with good reason and based on testing looking at braking and cornering. So changing tyres to a different size should not be necessary but if it is done it needs to be considered very carefully, and properly researched.
In theory you should adjust your tyre pressure based on the exact weight of the vehicle, that may be practical for Formula 1, but not for the average motorist so the recommended pressures do contain some margin of compromise because the weight of the vehicle will continually change by a small amount, even on a single journey.
In the front of most Haynes car manual both over and under inflation are shown and its effect on tread wear, so there is good evidence that its sensible to inflate tyres to the appropriate range.
Tyre pressure gauges available to the general public are not accurately calibrated so its quite possible for the measured pressure could be out by 5%, so its very difficult to be precise. So this is a factor that car and tyre manufactures have to allow for in their suggestions.
What is also important is to ensure that tyres on a common axle are inflated equally.
yeah its amazing i have those tyre monitor things as standard on the car,although all readings are supposed to be done from cold .but even then it can read 2 to 3 psi different from a summers morning to a cold winters day..and of course who has a tyre reading device that is spot on or takes into account the slight loss when one pulls the cord off the wheel valve... its a good job tyres can operate safety over such a big range of pressures...Sproket said:Out of curiosity i have left my tyrepal monitor on the dash all week, and the difference in pressure can be seen from a cold mornig showing 31psi cold to 36psi on the motorway on a warm day like today....
the van tyres can increase by + 10psi on a hot day when being towed. ..a few years ago i got in touch with dunlop and asked the question about the increase in pressure and was told that it was normal & taken into account when manufacturing a tyre.
So if in doubt ask the tyre manufacturer for advice .....
