Caravan awnings
I have seen a second hand caravan awning for sale the size is1025 and use on and elddis Crusader Sirocco which has an awning size of 1057. I have a Bailey Senator Wyoming with a awning size of 1042, is there any problem with using an awning of 1025?
Mar 19, 2005
23
Hi James
I also have a Senator Wyoming and have an Apache 1040 cm awning I think you might find that a 1025 will leave the awning high off the ground at the front and rear of the van especially if the ground is uneven. You could cut a piece of string to 1025cm and thread through your awning track to see where it ends alternatively if the price is right and you buy the 1025 and it doesnt fit you can adapt it with a Bradcot Patio pole which we have done on a smaller awning that I have adapted which we use as a Porch awning. An alternative would be to fix awning track on the van at the 1025 point but that is a bit drastic.
Hope of some3 use. Cheers John D
