Caravan MTPLM
Sep 19, 2006
40
Can any one tell me the MTPLM of my caravan . I have a Bailey Pageant Monarch year 2005
And I am thinking of getting a Vauxhall Antara automatic or a manual which is a good match JOHN
2,400
The information should be displayed on a plate near to the entrance door of your caravan John.
The figures I have found by using Google to look at a similar model offered for sale are:
  • 1,258 kg MTPLM
  • 1,082 kg MIRO
4,335
Hello John,
A topic concerning the same car has been running in the towing and safety section, and it may be relavent to you as well.
It all depends on what type of driving licence you hold. If you took your test after 1st Jan 1997, and you havent taken a further towing test, then you will only have Cat B for PLG vehicles. This limits you to a combined MAM of 3500Kg for the outfit.
MAM is the Maximum Authorised Mass of the tow vehicle and the trailer, and what is often not understood is that MAM is not what the outfit actually weighs, but what its maximum weight can be.
In the other thread there is concern about what the Antara's actual MAM is - it is found on the data plate fitted to the car and it will be the second biggest value on the plate. In the other thread it quoted as 2505Kg.
That means the caravan you can tow must have an MAM (safe equivelent is the MTPLM) of 3500 -2505 = 995Kg. As you can see if you only have Cat B (not BE or B+E) then the Antara cannot be used for your caravan.
Please check before making an expensive mistake.
Sep 19, 2006
40
Yes there is a plate on the caravan by the door it says MTPLM AND MIRO But nothing accross from them it blank at this side .
Thank you for your help
Aug 4, 2004
4,343
Get the auto as it is more than a good match for the caravan as it can tow up to 1700kgs and MIRO is higher than that anyway.
2,400
That's odd, the figures are supposed to be stamped onto the plate by the manufacturer.
If you have the CRiS certificate the MTPLM might be shown on that or Click Here for the contact details of the Bailey Customer Services Helpline if you want to be 100% certain
Oct 6, 2008
179
John,
I have an Antara auto and have just ordered my second.
You will have no problems at all.
To put in perspective my caravan has an MTPLM of 1630kg.
If i set the cruise at 56 mph my revs have never gone over 3000 on any motorway inclines whilst in D or 5th gear.
Mat
Oct 30, 2009
1,542
hi John,
parksy is right, BUT bailey use a stick on weight plate not a stamped one, and as it is by the door the lettering gets erased by washing ect and the writing gets obliterated very quickly " mine was illegible by the time it was 4 years old" however as it is a legal requirement to have a plate that can be read bailey will supply one free of charge if you contact their customer services,
Kelly who used to contribute to the forum sorted me one out very quickly,
4,335
john374224244 said:
My passed test in 1965 so can drive one thank you john
Thats good to read, On the face of it it looks like a practical proposition.
Happy caravanning
Jan 30, 2012
6
It would all take too long to go into detail, but I have been doing some checking up on the whole subject of MTPLM and the plate normally supplied by the manufacturer and it is all a lot more flexible than is normally assumed. I'm not asking anybody to accept what I say, or argue with me, they can check it out for themselves and form their own conclusions.
Basically, there is no official recognition of the term MTPLM. And the plate by the door isn't worth the bit of alloy it is printed on. There will, or should, be a plate on the drawbar, normally underneath the glass fibre, that shows the legal gross weight of the chassis. There is also a weight limit on the axle(s). In my case, my Elddis has an MTPLM of 1705kgs as decreed by Elddis, but the plate was missing when I bought the caravan. The axles, on the other hand, are 'plated' at 1050kgs each and the chassis at 2100kgs.
From what I can gather from VOSA, they are the figures that I can take as the gross weight of my caravan. Providing that does not exceed any other parameters, such as tyre weight limits (it doesn't) and the towing limit of the tug (it does) so I have assumed a GVW of 2000kgs to comply.
This does beg the question, why would Elddis - or any other manufacturer - use a 2100 kg chassis under a 1700kg caravan. Simple really, limit it to 1700 and you include a greater range of potential tow cars. There's nothing wrong with what they are doing, it makes good marketing sense and does maen that any safety margins are expanded.
Also, I believe that there are plans afoot, they may even be in operation now for new caravans to have a proper VIN style plate which will be a legal requirement, so this will only apply to older vans.
4,335
Hello Patrick
You are the third contributor to openly make this claim about MTPLM. Neither of the others have been able to point to the legislation that discounts the caravan manufactures specification as defined by thier data plate.
Please bear in mind that MTPLM has the same meaning as MAM,MAW, and GVW, so are you infering that these are also to be ignored also?
This is a very perplexing issue as despite extensive searches I have never found any official document that should give rise to this suggestion that manufactures data plates are to be ignored.Can you please identify the documents that give rise to your conclusions.
I currently beleive your contention is wrong, simply because the manufactures should be the best people to know what their products are designed to do, but I am not averse to changing my view given verifiable evidence.
Oct 30, 2009
1,542
hi John, while I agree with you regarding the MAM legistlation, I must add that I have heard the previous arguement before,
remember my post a couple of mths ago about my boating friend and the trouble he had with mr plod about a boat trailer,
the total upshot of it was, that the trailer chasis weight is the legal requirement not the whole trailed weight. (with previso) as the boat sat on it was just the load, the previso was that the trailed tow load was under the GTW of the towing car and the trailer chasis weight was not exeeded,
he argued in court that a trailer consisted of the "chasiss and load" where as the chassis weight was fixed, the load was not, as therfore as the load "boat" was under the designed weight of the trailer, and below the GTW of the tow car, he wasn't doing anything illegal . the court agreed and the charges were dismissed.
to put it in simple forms a car transporter can carry upto a certain weight plated on the chasiss, but can carry much less or even be towed empty, just because the chasiss weight has a maximum of 2 tonnes does not mean the weight is 2 tonnes as the trailer could weigh only 500kg when empty,
you could conceivably tow a empty one with a Mini but not carrying a Mini. if you follow,
in theory a caravan body is "just the load" on the trailer chasiss not the whole trailer so I can see the arguement.
but even though I do understand the principal I would NOT risk it as I believe that the authoties view caravans differently from other trailers simply because the load is fixed to the chasiss and issued with a weight plate separate from the chasiss weight plate that it is built on, the MTPLM or MAM is fixed by the van manufacturer and deemed to be that maximum weight, as far as I am aware the weight plate is a legal requirement, on caravans and the reason manufacurers will issue another FOC if it is damaged or faded. it can be increased or decreased on application for a fee but that does not negate the need to have one.
weight isses are complex enough without adding other dimentions to it.
Apr 7, 2008
4,909
When i looked under the cowl on the front of the A frame were the chassis information is stamped....
As you can see on the second line in the photo above 1600kg with a S value of 100kg for max nose weight
My MTPLM is 1600kg on the plate on the side of the van, ( below )
And on the centre of the axle it is stamped 1600kg......
So I'm sure that 1600kg is my MTPLM
With it stating GA 950 - 1600kg I wonder if the same type of chassis was used for the smaller two berth vans of the same model ?
Jul 15, 2008
3,901
1,088
........a trailer or a caravan has the MTPLM or (MAM,MAW,GVW) fixed by the manufacturer and they must by law fix a plate to the trailer or caravan stating what this is.
Nobody is entitled to change this except the manufacturer who sometimes will increase the amount for a caravan when requested to do so. They will issue a new plate showing the new MTPLM to comply with the law.
They can do this because they buy in the chassis upon which they build the caravan and this chassis can almost always carry a greater load, provided suitable tyres are fitted.
Only the manufacturer knows if the structure of the caravan built on that chassis is capable of taking the extra load.
Tom, Dick or Harry cannot come along and decide that because their twin axle caravan has a chassis that can carry 2100kgs, then it is OK to carry a 450kgs payload over and above manufacturer stated MTPLM of 1650kgs.
A manufacturer of a specialist trailer such as a boat trailer or a general purpose trailer, will construct and design it to carry the load up to the trailers plated MTPLM.
Apr 22, 2006
369
Without having the time to research this to the nth degree as some of you I will throw in a few points.
My experience is mainly with goods trailers and as a cpc holder of more than 20 years whom has had a few appearances due to drivers running incorrect axle weights etc this would lead me to agree with most of what has been said before. Plated axle weights cannot be exceeded neither can plated gross weights. Call the terms by whatever you wish but to me that plate by the door equals the same plate attached to my work trailers and trucks by VOSA. Yes these weights can be changed and replated but what is there at the time is what is in force.
For those of you who think these are not binding please check various other threads on here re license requirements. You will see there that the max allowed trailer weight is used when working out the maximum train weight for drivers license re whether they need a B+E etc. This is also why manufacturers may choose to use lower limits than the trailer is capable of. To suddenley think you can switch between them as suits is daft, either that or I need to be thinking about using you for legal services.
4,335
Hello Colin,
As I understand your post, the example you give is the not same as the claims made by some other members. In your friends case he was arguing the authorities should use the trailers measured weight rather than its MAM. Now its not clear from your details what you friend was being accused of, was his licence entitlements or was to do with an overloading issue on the car, because the the criteria are different.
There is also a major difference between a boat trailer and a caravan, in so far that the boat trailer is designed to allow the boat to be loaded and unloaded, A caravan body is not. A caravan is supplied with its body 'fixed' to the chassis and it is not designed to be a demountable container thus the body and chassis are considered as a single entity. They also draw mutal structural strength and stability from each other.
In the case I am queering an it's an overloading issue on the trailer. It is claimed the authorities would weigh the trailer and say for example record it at 1800Kg where as the caravan manufactures MTPLM/MAM/GVW/MAW was only 1700Kg yet it was built on a chassis that is rated to 2000kg. (these are just example figures)
In this case the axle load is not exceeded, BUT the manufactures MTPLM/MAM/GVW/MAW is exceeded. A few members claim no offence has been committed; because the trailer was within the chassis manufactures limit of 2000Kg.
I have searched and found no evidence to support that contention. It is even an illogical suggestion, as it means the authorities are allowing a body design to be overloaded with the raised risk that the body will fail. Bear in mind that this applies to all trailers not just caravans, so the load could be a dangerous substance where a failure could have major consequences.
In a similar vein its like a car where the manufacture states an MAM of 2000Kg but the sum of the tyre load indexes adds up to 2400Kg being allowed to run at over 2000Kg. Its an unsafe engineering solution because the weakest links limit has been exceeded. It is also highly unlikely because we know the authorities stick to MAM for motor vehicles. I cannot see them changing that principal for trailers.
In the light of these claims of VOSA ignoring manufactures MAM specifications I would like to be able to ensure that any future advice I give is accurate. To do that, I need to be able to see sight of the regulation or legislation that directs the authorities to work in that manner. So far no-one has supplied links or information that points to an official document instructing VOSA to work in that way.
One menber has claimed he has posted evidence, Unfortunately I do not recall it and the forum search facility is of no practical help or perhaps it was not definative or verifiable, but he seems reluctant to repost it, which is a shame, becasue it might be whats needed to put this matter to bed.
Until that evidence is actually forthcoming and verified, the only safe option is to continue to assume that the bodywork manufactures specifications take precedence over the individual parts suppliers specifications.
Jul 15, 2008
3,901
1,088
Prof.......don't bother asking for proof that your contention is incorrect because it isn't.
Anybody who has had experience of working with VOSA in the commercial world of trucks and trailers will tell you how they operate.
wee jock has described very well how they interpret the law.
There are differences with commercial trailers over 3500kgs in that the weight plate is issued by the Ministry of Transport and not the trailer manufacturer. It too must be affixed to the trailer at all times and is subject to inspection at the annual MOT test of the trailer.
The trailer will fail the test if the plate is missing or has been tampered with.
This system leaves no room for argument as to overloading or maintenance issues.
With caravans (and trailers under 3500kgs) the Ministry delegates the values displayed on the weight plate to the manufacturer and as we all know caravans are not subject to an annual MOT test.
This apparent lack of official status given to a caravans weight plate coupled with no annual check to see if it is still attached seems to have confused some people.
It is unlikely that the courts or insurance companies will be so confused!
I understand that new regulations come into force for new caravans and trailers (under 3500kgs) from next month to comply with European Type Approval.
I have heard that the weight plate may well have to show more detail and be even more important
Jan 30, 2012
6
My original intent was to have my say and leave it at that, but
as all the responses are well considered and sensible I thought I would reply
to as many points as I can. However, let
me say that I would not for one second suggest anybody else do what I have done
without making sure that they have checked to their own satisfation that this
is correct.
Prof John L: You are the
PS: No and nor can I,
because it doesn’t exist. The point is
that there there is no legislation that requires the MTPLM to be regarded as a
legal requirement. In fact, there is no
reference to the term MTPLM in any VOSA sources that I can find.
Prof John L: Please bear in mind that MTPLM has the same
be ignored also?
PS: On that I
disagree. The MTPLM is stipulated by
whoever fits the body on the caravan and subsequently markets it. The chassis manufacturer, on the other hand,
sets the legal weight limits (MAM, MAW, GVW) which are set out on the plate on
the chassis. As the chassis
manufacturers only produce a limited number of chassis configurations (length,
width, weight capacity etc.) the caravan manufacturers will chose the one
closest to their required configuration and then, quite understandably, set an
MTPLM that offers the widest possible market for their product. And this
is why, manufacturers can provide plates upgrading the MTPLM with no more in
the way of documentation than a cheque for £30.
Prof John L: This is a
PS: I have to agree with
you there. But again, no there is no
legislation saying that manufacturers data plates have to be followed
either. There is legislation regarding
VIN plates on cars and on the chassis manufacturers plate, but that is a
different matter altogether.
Prof John L: I currently beleive your contention is wrong,
PS: An eminently sensible
stance. In fact it was that paragraph
that persuaded me to respond. I knew
this might be a bit contentious and, as a newbie, if I had been simply told I
was talking nonsense I would have let the topic drop. Equally, if someone proves to me that I am
wrong – which is far from unknown – then I will recant.
Colin-yorkshire: (edited) the total upshot of it
but
need to have one. weight isses are
PS: As your friend found out, these things need
to be argued in court, which may well happen.
But I would disagree with you that the authorities view caravans
differently. The law dosen’t work like
that. A trailer is a trailer and
although there are some differences in the legislation for trailers that do not
carry loads – generators and the like – the authorities cannot cherry pick
which bits they want to apply just as it suits them.
Much of my
research was done on the phone because getting anyone in a government
department to commit to anything in writing is close to impossible.
Gafferbill: ........a trailer or
PS: The question
has been raised as to where it says in law that a caravan manufacturers plate
isn’t a legal requirement? As I’ve said,
it doesn’t. So, where does it say, in
law, that you do have to have one? And
yet again, why is the MTPLM being taken as exactly the same thing as the
MAM,MAW or GVW?
Gafferbill:
with the law.
PS: Who says so?
Gafferbill: They can do this because they buy in the chassis
Only
Tom,
A
PS: Again, this is the
generally held opinion, but that doesn’t necessarily make it so. Chassis manufactures will, of course, allow a
hefty safety margin and so do the manufacturers of the bodywork. Elddis would provide me with a new plate – we
didn’t get as far as how much they would up-grade – for £30, if the van were
newer. I believe (from another source) that they would have provided me with
900kgs on the caravan if it had been a year newer. That happens to be my self-imposed limt. I find it difficult to believe that the
safety margin built into a caravan isn’t sufficient to allow a ten per cent
invrease over that 1900kgs without becoming unsafe.
Wee Jock: Without
in a few points.
My
For
PS: I agree with what you
say in that the trailer plate is legally binding, as is the one on the chassis
of my cravan. The fact that it is not
the same as the one by the door is where my argument lies. The one by the door serves as a quick
reference, and VOSA may even prosecute on the strength of it. They’ll probably win too unless
challenged. However, if it is not there,
or even replaced by another plate with the chassis and axle limits (on a TA)
then they will go by that.
No, I have no written proof of any of this, anymore than there
is any written proof to the contrary and most of my information was, as I have
said, gathered from lengthy telephone calls to various people in VOSA. And the over-riding impression I got was that
the whole thing will only become clear if there is a test case and it is
unlikely that VOSA would want to go down that route.
Prof John L: (edited)
PS: I don’t think
the two are really the same thing. Many
commercial vehicles – possibly cars too – have the axles with sum of the axle
loads at a higher rate to allow for reasonable load distribution. It would be almost impossible to load a van/truck
to its maximum weight without this and that would make the van very
inefficient.
In the case of my caravan chassis the gross weight allowed
is 2100 kgs and the axles are both on the plate and individually stamped at
1050kgs. In my opinion that immediately
knocks 100 kgs off the gross weight because if the caravan is to have any
noseweight the front axle will need to be taking a bit more load than the back
axle. So, assumng I could load the
caravan accurately enough to get 1050kgs on the front axle then the back axle
is going to have a bit less.
Prof John L: In the light of
that way.
PS: I didn’t say
that VOSA was ignoring the MAM plates, I said that the MTPLM plate had no real
value in law. However, if the MTPLM
plate is missing then VOSA will check the trailer manufacturer’s MAM plate
which is legally binding.
Prof John L: One menber has
PS: I don’t see how
they can have posted evidence. I could
find nothing in writing that verified this one way or the other.
Prof John
L:
specifications.
PS: Despite what I have
said, this probably is the best option.
My point was that I have decided that I am satisfied that what I am
doing is both legal and safe and will continue to do so. I wouldn’t want anybody to follow in my
footsteps without having satified themselves that this is all OK.
I suppose my other point in starting this was that we live in a
world where there are so many assumptions that things are ‘the law’ when they
are not. How many times have you heard
it said that the ‘85% rule’ was the law?
I’ve even met someone who was told by a dealer that cravans had to be
white, by law. That I could almost believe.
Anyway, if this goes no further, many thanks for an interesting
and well thought out debate.
1,819
My feeling on this is that the legislation is so confused that the arguments put forward would be beyond the expertise of most magistrates and a prosecution could result in any finding. Essentially you exceed the MTPLM at your own risk.
It does seem to be a fact that many manufacturers will increase the MTPLM of some of their products without any modification if asked which does beg the question are they being kept artificially low to increase the number of towcars that can tow them?
Oct 30, 2009
1,542
hi John,
of course you are right, in so much as the case involving my friend was different, in fact the other way round. however the principals invovled were similar, as a brief outline, he has a fishing boat at the coast every year as winter approaches he brings it home to do servicing, repairs, and protect it form winter storms. he has it mounted on a break-back trailer rated to the boats weight ie 1500kg max MAM ie boat and trailer, he tows it with a mondeo est, now this time when he was due to bring it home the trailer had a fault (wheel bearing) so he borrowed one to do the job, this trailer was much bigger though and had a two and a half tonne capacity,
on the way home he was stopped by mr Plod -because to use his words " thats a big trailer " got an HGV licence for it" my friend tried to explain that although the trailer looked big the combined weight was less than the trailed axel load for the car,
but he was having none of it, he refused to let him proceed until someone with a bigger tow vehicle could fetch it, and issued a fixed penelty notice for using a over weight trailer because the plated trailer weight was over 2 tonne and too big for the car even though he made no attempt to weigh it.
in court my friend sucessfully argued that although the plated weight was in exess of the the capacity of the car the actual tow load was less, he produced photos and weight certificates to back this up, and the majistrate agreed and dismissed the case.
now what has this to do with the current thread well maybe nothing exept that it goes to the issues of fixed weight plates. while it states the maximum trailer weight this does not mean it is the actual trailer weight.
in caravan terms that means just because it carries a weight plate stating the MTPLM is 2000kg the van may not weigh more than 2000kg but could be towed weighing less possibly closer to the MIRO of say 1350kg so a car capable of towing 1500kg could tow the van empty but not loaded, thats what his court case meant to me
it is easy to see how the argument could be turned on it's head in that if no other weight plate was visable and the only one to take a reference point from was the chassis, loading a van up to this weight would be ok.
HOWEVER the issue I have with this it that the "vans manufacturing weight plate" should be visable and this takes priority over the chasiss plate, I have no idea when the legsitlation came in, as only the bailey has one "all my old vans" just had the weight stamped on the A frame like (16 CWT) and had no mention of MIRO's or MTPLM's.
all I know is now it has one that is the weight I will use that fact that the chasiss is stamed 1300kg is of no consern to me at all.
Aug 4, 2004
4,343
Thank you as that is what I have been stating all along, but no one accepted it!
Aug 4, 2004
4,343
Incorrect as the plate a caravan manufacturer sticks on your caravan has no legal basis in law as it does not comply with the conditions for a statutory plate. Secondly some plates are easily removable as they are stuck on and not fixed. The plate that is fixed onto the trailer chassis is the oen that counts and where you can be prosecuted.
Jul 15, 2008
3,901
1,088
OK .......you will not believe me so do you believe the National Caravan Council?
Probably not would be my guess
Maximum Technically Permissible Laden Mass (MTPLM)
(Maximum Authorised Mass)
As stated by the caravan manufacturer on the caravan weight
plate (usually mounted close to the entrance door) – the absolute
maximum weight that the caravan must not exceed to be legal on the road.
It includes the allowances for the user payload – all fluids (water
etc) and personal belongings that you may wish to carry (clothes, food
etc).
http://www.tourerinfo.co.uk/payloads/
http://www.tourerinfo.co.uk/payloads/pdf/TC-Payloads-FAQ-final-revision.pdf
