Caravan servicing?
4,573
I have recently use Mark Lewendon, www.markcaravanmedic.co.uk he does 40 miles radius of the Milton keynes area, he is also the chap for Powertouch warranty, repair for this are, well recommended.
Dusty, just tried out my damp meter, and if I have it on "Construction" and not wood , it reads the same as the service engineers readings, so now I know, Again.
Aug 23, 2009
3,167
Does this damp meter have probes? Just asking because if it does it won't be any good for us. :(
5,348
Martin
As Hutch says , yes. They are very very sharp. A protective cover is supplied when not in use.
When in use you must push the probes firmly into the surface so as to penetrate the plastic wall fabric. They will leave small puncture marks, virtually invisible. So most people tend to pull back the window rubber seals and insert the tool there. Under the seats on the walls near to the floor is another good area. Basically test at all joints and apertures. If you get a damp reading in the centre of the wall then I'd say you probably have real trouble on your hands :(
Aug 23, 2009
3,167
Our walls are lined in GRP which means we can't use the probe ones at all. A pain in some respects but easier than wall board for hanging works of art :)
40
What is 'qualifed' ?
I happen to be a Fellow of the Institution of Mechanical Enginners, having been a mmember of the Institution for more than 50 years and having held senoir management responsibility in bot private and public sector industries, signed off safety critical work in both, managed a Department of close on 1000 staff in nuclear industry etc. So Am I really qualified to service my own caravan.
Answers on a postcard please
Mar 2, 2017
12
Qualified, yes by the sounds of it.
Authorised by a caravan manufacturer, no.
Jul 11, 2015
482
Hello fellow Fellow. Our professional registration allows us the opportunity to challenge the stupidity of modernity where unqualified people have misinterpreted things and created the society we have now.
Like you, my pedigree is in intrinsically safe environments, a bit more than the big kettles you've had in nuclear :p
I blame poor education.
4,573
Hello, Fellows, I believe, like several Fellows of foundations, you pay to have a membership, As a British Licenced Aircraft Engineer we, are Governed , and Licenced, by the British Goverment we are competent to certify Certain Aircraft, but still cannot sign off our caravans or Motorhomes, ******. :( :(
4,573
Dusty, just to double check, when using the damp meter, do you use it on Construction or Wood
Jan 24, 2015
187
Qualified or competent?
Does qualified only mean you've taken the appropriate exams following a period of study or training?
Competent on the other hand is based on aquisition of underpinning knowledge, training, and experience to properly carry out the task.
Just a thought!! :cheer:
May 27, 2014
219
10,585
I've got an old 1998 caravan in fairly good condition - I'm not qualified in anything - I do however know how to hitch me auld van to my car and head off to the hills - chose a site with good nearby amenities and bobs your uncle !!
Who was this bloke bob anyway ???
5,348
Missed that one.
Hutch
Never used on construction. Will have a go tomorrow.
I think wood will retain more liquid than say concrete will hence the two settings.
