Carver Crystal 2 Boiler.
Sep 22, 2005
11
Although I've been caravanning for more years than I care to remember, I still have an question that someone may have the answer to or an opinion about. Having heated up water in the boiler with the immersion heater can the hot water be used for general cooking purposes?. It seems a bit of a waste having heated it up only to use it for washing/washing-up purposes. Any views folks?
4,336
Hello Peter,
A minor point, the Carver Crystal is a water filter and the Cascade is the water heater. As both the Carver and Truma heaters do not "Boil" the water they should only be referred to as heaters.
As with any domestic hot water system it is unwise to use water that has been stored at an elevated temperature. Both the Truma and Carver water heaters retain an air cap above the water, and this is a potential site for bacteria and the deadly legionalla.
If the systems did boil the water then the dangers would be much reduced, but as they only heated to a maximum of 72C and more typically only 55 to 60, then it is possible that the water could become unfit to drink or ingest.
It is also another reason why regular cleaning of your water systems with an appropriate agent should be carried out to reduce the risk of contamination.
Sep 22, 2005
11
Hello Peter,
Thanks John L, a relevemt point, as you say water that has been warmed and stored should not be used for drinking. I was thinking more of heating for boiling vegetables, but as you indicate caution should be the guide line.
