Cassette toilet flush
Aug 17, 2019
106
18
4,585
Anybody got any idea's about the flush on a cassette toilet flushing slow and is there anything i can put into the water to clean to the pump out any idea's would be gratefull
Jan 19, 2002
1,498
419
19,435
It may be that the pump is getting blosked with algae especially if you also have blck bits in the flush water - an earlier thresd discussed cleaning which may help
Aug 17, 2019
106
18
4,585
Thanks for the advice will try milton the caravan is only 12 months old and used to use pink but stoped and now just use fresh clean water but the pump does'nt seem to have as much presure and force like it used to do
2,884
In the first two years of our caravan being new we had Black bit being flushed through. Drained the system a few times and all was good. Used pink since then and no problems the last 8 years.
Sep 12, 2022
The pump might be getting blocked up with black bits. These form if using too much of the pink flush or not draining it down regularly. Try flushing some puriclean or milton through it.
