It's clear from the correspondence on the thread so far the combined knowledge of the PC contributors has not found the solution to your dilemma.Why do you think I am posting on here? 🤔
Thank you. I have tried other Jeep related sources, but my initial question was about charging the battery while connected in the vehicle and that question was answered more than adequately.It's clear from the correspondence on the thread so far the combined knowledge of the PC contributors has not found the solution to your dilemma.
Your problem seems to be model specific. It's far more likely a forum dedicated to the make or model vehicle is far likely to have come across a similar dilemma and may have already worked out a practical solution.
You seem reluctant to use a Jeep dealer, I assume through distance and cost, so a forum dedicated to the marque and possibly model is far more likely to have more detailed knowledge and may already have an answer for your problem.
I'm not suggesting you shouldn't be posting on PCF, but it seems you are relying on it when there may be a better informed source of information.
Didn't Beachball have some funny electrical gremlins on his Ford Tonneau which were thought to be battery related. There's no doubt modern cars are very integrated wrt their systems and the battery/alternator is a key part of the system. I recall the President of the Volvo Owners Club drove from Devon to London and did not like SS, so switched it off. On leaving London the car would not start and the Breakdown technician said it was because the SS was off for so long. Don't know if that was true or not but it was back in 2012.SWMBO 8 year Kia oem battery let us down at sub zero degs last week. 12.6 v on multimeter after smart charging. Now looking for a new battery. As it’s a start stop the recommended battery is nearly twice the price. Circa £250.
So I’m not surprised the Jeep is nearly £500.
You have mentioned a number of weird electrical issues. I guess the only way to establish causation is plugging into Jeep’s diagnostic kit at a Dealer. If it is the battery and it fixes the issues all well and good. But if it doesn’t you may end up throwing money at replacing both batteries when the problem is something else.
Very annoying but that’s the problem with all this hi tech stuff today.
I googled Jeep battery problems and this cropped up. It tells me the life expectancy of Jeep batteries is not as good as other makes.Not sure who made your original battery?
Top 3 Problems with the 2019 Jeep Cherokee Battery | Robison Lemon Law Group, LLC
Battery issues are among the biggest problems that affect 2019 Jeep Cherokee owners. If you know how to identify and correct Jeep Cherokee dead batterylemonlawcar.com
The original battery is supposed to have been a "Mopar" battery or probably a rebranded Bosch, Varta or Exide battery for Chrysler. They are definitely not worth +£500 before cost of fitting. The equivalent Bosch, Varta or Yuasa AGM battery is under £200 including fitting.SWMBO 8 year Kia oem battery let us down at sub zero degs last week. 12.6 v on multimeter after smart charging. Now looking for a new battery. As it’s a start stop the recommended battery is nearly twice the price. Circa £250.
Thanks I have tried just about every link and the end result did not make sense which is why I have been asking around on various forums, but no one seems to know for the Bosch battery. Unfortunately not the easiest battery to remove from under the seat to check for any other markings.The link below is supposed to help you identify the origins of a Varta or Bosch battery.
How about e mailing your photo to Bosch and ask them ?
Google Search
www.google.com
Thanks Dusty as I had similar for the year, but thought I got it wrong as the car was built in 2017 and normally the vehicle gets the Mopar battery which is a rebranded battery. However being the EU maybe the Bosch is the original battery.Looking at the Q code on yours
B 22 08 110 3J7
B = made in Spain
22= ??
A = 2018
08= August
110= Day ie 11th
3J7 = battery model serial number
All according to a Russian Bosch site😎
According to the build sheet or VIN the car was manufactured in late 2017 although only registered in March 2018. We have had the vehicle since Aug 2022 and in that space of time we have not even done 10000 miles with the vehicle. It is mainly used for towing and long distance trips as we use the Corolla around town.If it's a 2017 car with a 2022 battery of different make to OE fitment, it's reasonable to assume that it was replaced at 5 years old but raises the question why the new battery needs replacing after just 2 years, a Bosch AGM is normally high quality.
That’s my concern so I have asked my long trusted mobile mechanic to supply and fit a new AGM battery, Exide 3 year guarantee to the Kia. £250.59.Raining on and off today so cannot disconnect the aux battery to check. The other concern is losing settings if both batteries are removed at the same time. Scouring Jeep forums to see if there is any effect?
According to the more knowledgeable on Jeep forums the Jeep does not require the battery to be registered when it is changed which was a worry.That’s my concern so I have asked my long trusted mobile mechanic to supply and fit a new AGM battery, Exide 3 year guarantee to the Kia. £250.59.
On the RAC site I inputted my registration number and it came up with 3 batteries for the Jeep. However on checking details none of the batteries were suitable for Stop Start vehicles!A Varta AGM for our Kia Rio (1.25 sewing machine)is quoted at £343 fitted by RAC mobile. 👎
What is a 1/4 inch square drive or a 3/8 square drive when dealing with Rachets?
Thanks I suspected as much, but needed confirmation. The sockets that I have are 1/2 inch.Just the size of the square hole in the drive end of each socket.
There is also half -inch and most likely bigger still for strong people.
Do you know what test/tests he did? If you drove to him and he simply tested with a volt meter when you arrived it doesn't prove anything. I have a car battery in my garage that I know to be failing but it's been sat at 12.7 v for almost a month (off charge).Anyway he went under the hood unlike the other two previous fitters and did the tests. He then showed me the results and the battery reading was 12.6v! I am guessing that the terminals under the hood are for the main 12v battery. He could not test the aux battery while it was connected and he was not allowed to disconnect it.
