Checking tyre pressure on Caravan
What’s the problem with Von Haus being made in China? It’s a respected make, retailed by many reputable British outlets. I don’t understand this paranoia against items made in China. I bet if you did a domestic, caravan and car inventory you will find numerous items made in China , all of which are doing their job perfectly well.
My Alko mower has a Chinese engine, and given seven years faultless service.
I do not recall stating that there was a problem with it being manufactured in China so please do not jump to conclusions..
What isn't these day
As per posts in another thread. The name can give the impression that it is made in Germany. Pity there is no legislation that enforces the seller to state country of origin. The consumer is then better informed and can make a decision based on their preferences.
Looking at a replacement Truma Ultrastore element a few weeks back I found exactly what I wanted, £100 cheaper than the Truma oem.
I discussed it with my AWS engineer. A big NO!
Sold on E bay made in China, five year warranty . Very tempting. He said never fit non oem bits to a gas appliance.
So why are the Chinese making such a specialist part that is probably not a high volume seller?
Sadly MG is no longer from Abingdon more Shanghai😥
There is a growing caravan market in China so perhaps they have copied Truma OEM appliances and their components, and in parallel decided to market the parts elsewhere.
In Oz in 2021 40% of RV sales were Chinese imports.
View: https://www.reddit.com/r/GoRVing/comments/u2iryr/traveling_in_china_by_rental_rv_caravan_some/
I suppose kicking the tyre is no longer compliant🤪
You need a British Standard foot, safety boot, and it must be done at sea level with an ambient temperature of between 21 and 25C and barometric pressure of 775mmHg with humidity not exceeding 75%RH with no precipitation. The boots toe cap must contact the tyre must on the forward facing side of the tyre 3.1/4 inches from the floor, with a velocity of 3ft per second in the horizontal component. the bounce back must be measured, and the distance read off the table of pressure bounce back values for make and model of tyre.
Buy using the prefered method you can assess the pressure in the tyre with a precision of about +/- 30 psi on Wednesdays or +/-40 psi every other day
Somewhat Fred Drift but why not.....
Stuff is made all over the world these days and you get good and bad quality items from wherever its made.
Back in the seventies in South Africa we would only buy British made goods as quality was superb. It took SA several years to produce similar quality goods. No goods imported from China.
In the 1970s there were very few, if any, goods from China imported in to Britain either, with the exception of some items from Hong Kong.
Didn't know Alko made mowers.
Actually I also didn"t know AL-KO did lawnmowers but we went for this because our garden not to big
Einhell GE-CM 18/33 Li Cordless Lawnmower so far very impressed
Despite taking as much precautions as I can I sometimes wonder if I'm still being tracked on the Interweb.
After asking about battery powered tyre inflators and looking on Amazon...not logged in.....today, as part of my review programme with them, I get offered this from f.o.c. plus another 12v powered version and two digital tyre pressure gauges.
Today, just going out and tyre low pressure warning came on, using the Cycplus inflator, the one I mentioned in the thread. It took about 5 minutes to raise my tyre from 30psi to 34 psi. Tyre is 235, 65, 18. So a big tyre. Still 3 power bars out of 4, so happy boy here. Recharge from car socket.
Hutch about 5 mins is a long time to raise the tyre 4psi?
Your blurb says it goes to 150 psi.
Will you be there all day achieving that level😁
I jest but it makes you wonder about manufactures promises
My tyres are similar size and with my foot pump I can increase them by 4 psi much quicker than 5 minutes. Even my cycle track pump would beat that time, and I get a work out too😱
I also have a rechargeable tyre pump which makes life a lot easier when it comes to not having to connect to the car. Also use it to inflate my loc and level when on site. But as stated it doesn’t do anything quickly and can take a few minutes to go from 60 to 65 psi. I don’t think it has the battery capacity to adjust four tyres on my truck by too much. Something to consider.
As we no longer have a caravan, we will have a Tyrepal. TPMS for sale amongst a million other things. OH is getting tired of seeing all the caravan stuff in the small bedroom! 😆
