Choosing an awning
Oct 14, 2021
I am trying to decide what sort of air awning to buy for my caravan. The one we have is too big and too heavy, Kampa Classic Air Expert 3.7 metres.
Need a size of 2 metre / 2.6 metre.
We usually do trips of 2 weeks, 5 times each year.
Going to NEC show next month to have a look.
Would anyone have reccomendations please?
8,188
On our last van we had a Dorema Quattro 225 which did us fine all year. They do a slightly longer one too. Always found Dorema quality to be good. I preferred poled as I could stow the awning and poles separately. .
4,684
We had a similar issue with a large Kampa air awning and bought a 220 air awning mainly for the cooler month. We have the Magnum poled awning which is a lot lighter to handle than the equivalent air awning and that has been used in the summer months however this year we are going to try using our sunshade a lot more to see it it is better. Easier to erect than any awning. :)
Reactions: GUMPY
8,188
Here is a photo of our Dorema Quattro 225. The doors remove, as does the front section, which can be used with the veranda pole to give a measure of enclosure.
8,188
That looks quite smart. Our 220 air awning has only one tube across the front. It is quick to erect even using a hand pump.
Only problem with porch awning on that caravan was that the space between the front door frame and the side window was minimal. So prior to erecting the awning I would wipe the window down and also wipe the forward vertical section of the awning. The foam section that seals the forward side. I also had small screw keeps /stoppers. that fit into the awning rail front and back and they restrain the awning from moving backwards and forwards. So in a nutshell despite being non optimum I never had any scratches on the window. But it’s a pity caravan makers don’t allow for a bit more space by the door as porch awnings are rare.
4,684
We used pipe lagging which stopped the window being scratched.
4,031
Here is a picture of our very light Sunncamp Air 260. About 8 years old now. It copes with rain but Not storms.
Reactions: Saxo Appeal
8,188
Insulation you would put around an outside pipe?
I know what pipe insulation is and what a pipe is, but I don’t understand where a “pipe” comes into it as I was describing what I did to stop the awning scratching the caravan window.
4,684
I am sorry but for your benefit I have corrected my post. :ROFLMAO:
2,395
This was our Vango Capella 220 Air porch awning we never had a problem with the Draught seal system creates a tight seal between the awning and caravan even in breezy conditions
