Classic Newbie questions.
2,884
I use bathroom scales and put brick or wood under the hitch with the van just slightly higher than when hitched up then lower it onto the scales with the jockey wheel. .until jockey wheel as just clear.
1,793
If you buy from a dealer they should include the hook up cable and steps, if buying privately check what you are getting with the seller.
If you use bathroom scales to weigh the nose weight you need a length of wood in the hitch cut so that you measure at the height of the tow bar. using the jockey wheel gives you a reading that can be seriously out.
2,086
Using the jockey wheel doesn't give a figure that's seriously out - it's only slightly out by the same proportion as hitch to jockey to wheels - likely to be within 5kg.
