Cleaning awning windows
Ty
Apr 18, 2018
67
8
1,585
Hi All
Does anyone know what is best for cleaning the plastic windows on a kampa awning.
Ty
Feb 23, 2018
928
93
18,935
ProfJohnL said:
Check the manufacturers instructions.
Kampa FAQs do not specify how to clean the windows, only the awning as a whole: "Dirty awnings can be washed using clean water and a soft brush. Do not scrub and never use detergents."
Isabella also echo this advice but also add that you should "NEVER use spirit or polishes on the PVC windows."
Apr 19, 2017
361
I just hose them down (or splash water from a bucket) to wash off loose dirt. Then if necessary sponge down with warm water with just a drop of detergent and finally rinse again. Has never done any harm.
Jun 11, 2012
1,533
33
19,685
Try a week solution of washing up liquid on a sponge . It works on ours but just enough to get the suds to their job .
Sir Roger
2,316
Do not do this without checking out what I am about to say because you could end up with a VERY RUINED awning, but I think I heard somewhere that WD40 would clear plastic awning Windows that had gone cloudy.
I may have made that up but the fear of confabulation has never Stopped me before.
Seriously double check before getting out the can.
3,037
Ive once used my auto glym glass cleaner to when i had all my stuff away with me . Worked a treat , unsure if id use WD4o though ?! :unsure:
Ty
Apr 18, 2018
67
8
1,585
Thanks all, they are still like new awnings only 6 months old just general dust and now seagull dropings well more like a paint splash all over one of them.think ill just try the warm water and a sponge. Thanks again Ty
Jun 11, 2012
1,533
33
19,685
WD 40 ????? Damian will tell you there is no place in a caravan for WD40.Be safe and use the washing up liquid method I posted earlier. If you have headlamps where the lamp protectors are starting look a bit green then WD on kitchen roll will clear thelenses but if they have too bad you have to work on them ,
Sir Roger
