I have a Thetford dual fuel cooker, model SCK23000 and the temperature will not regulate.
Mine has never worked corectly, just turn it to max and keep checking it, and we never bake a cake in it.
Thanks Hutch, This seems to be a common fault with these ovens, our oven appeared to work normally for the first five years, and looks like it could be an expensive fix so I think we will just live with it.Mine has never worked corectly, just turn it to max and keep checking it, and we never bake a cake in it.
Thanks Parksy, Your right with your comment, I think we will live with it, and we have a slow cooker in the caravan that will definitely come into play.The Thetford oven in our caravan has the numbers on the dial, but in reality it's either on full blast or very low.
It hasn't got the amount of control that our electric cooker at home has.
I find that because the caravan oven is a bit smaller than the home one ours can get quite hot, so I have to make adjustments to prevent food from burning.
If I'm going to oven cook anything in the caravan now I tend to use my electric slow cooker if possible, a recent addition since it was replaced at home with a better model.
Thanks John.Thinking about that. Ours seems to work in that it regulates and will turn down. But whenusing on a high setting, food has to be cooked much longer than it says o the packet. So it does not reach the same temperatures as the oven at home.
We find the grill does work, but is not that efficient. Can be patchy and needs things moving when used.One of the worst aspects with the Thetford is the grill which is a grill only in name as you cannot grill anything under it. We have never used the grill in our current caravan as we have the same model of Thetford in this caravan as in the previous caravan.
