Hi
My van is just a year old (2017 Sprite Major 6) when I recently went away I followed the same procedure on pitching up.
I levelled the van using the jockey wheel then when I went to use the front nearside corner steady wind down nut it was out of line with the circular hole in the trim and I couldn’t access it. I then went and put down the rear steadies just with a bit resistance and went back to the offending steady nut, hey presto it was central in the hole like it should be.
This happened again when I took the van back to storage. Is there something wrong with the van or am I doing something wrong?
