Courtesy and brake lights
Devonisheaven
BANNED
Aug 18, 2024
326
214
935
My Santa Fe, auto hold on hand brake , or electric, hand brake are both electrical input to a servo, to a cable brake on the rear brake shoes.
But the system puts on brake lights when sitting idle.
Brake shoes! Blimey hutch how old is your SF?
Devonisheaven
BANNED
Aug 18, 2024
326
214
935
The Park position in auto gear boxes is not neutral, its an arrangement of the gears where they mechanically lock to prevent rotation of the output drive shafts, whilst the clutch is disengaged, so the engine can be started.
Yes, the gearbox is effectively locked, but I am a little confused by “while the clutch is disengaged”
Devonisheaven
BANNED
Aug 18, 2024
326
214
935
The Auto Hold, and parking brake are two separately operated system. I love auto hold, it is one of the many advantages of an automatic, it simply applies when your braking and the car comes to a standstill, releases when you operate the throttle. Hence your brake lights are on, as the brakes are applied.
When the parking brake is applied, the system engages just the rear disc brakes. Some manufacturers used to have a separate, small, drum and shoe system, within the rear brake disc for the handbrake/parking brake, but many done away with that when I was in the motor trade……..and that was decades ago!
5,168
The conventional meaning on neutral, means there is no mechanical linkage between the engine and the output drive shafts. This is why you can push a car when its in neutral without turning the engine. If a vehicle is rear ended when the gearbox is set in neutral, any resulting movement of the vehicle will not cause gearbox damage. The Park position in auto gear boxes is not neutral, its an arrangement of the gears where they mechanically lock to prevent rotation of the output drive shafts, whilst the clutch is disengaged, so the engine can be started.
Manual gearboxes don't have a "Park" position
Does anyone still drive a manual car? LOL! Obviously I was referring to an automatic gearbox as I have never come across any manual gearbox where you can select Park, but happy to be corrected?
8,955
Actually, autohold just maintains the pressure in the brake pipes BUT after 2-3 minutes and especially if you are facing down a slope the full (hand) brake is applied and the green authold light changes to red. Had two Passat Estates and now have a Karoq and they all work(ed) like that.
You can of course just pull the handbrake switch and do it yourself!
Mercs, most BMWs, and Volvo's all do it as well.
My Toyota removes Autohold after about 5 minutes and applies parking brake. Rear brake lights then go off. Not dissimilar to yours.
4,489
The 2014 Santa Fe has the hand brake / electric handbrake , operating on cables to brake shoes, operating inside a drum on the rear discs.
This morning I have just received a recall on the Hydraulic Electronic Control Unit, for a fuse rework.
Devonisheaven
BANNED
Aug 18, 2024
326
214
935
So ten years old now, some manufacturers phased that system out decades ago…..You live and learn. I have not worked on vehicle brake systems for around d 30 years.
Devonisheaven
BANNED
Aug 18, 2024
326
214
935
Looking at my neighbours Captur a 24 registration the rear has drums which I assume have shoes inside them.
Yes Clive , it isn’t unusual for a smaller, lighter car to still have drum brakes, at least the wheels don’t get covered in that awful brake dust! The front brakes do the majority of the “stopping” the rear brakes help the car keep in a straight line.
Having said that, the tow cars we need, larger cars that need to tow at the very least 1.1t will, or will preferably have disc brakes all round. 👍
4,489
And you still adjust the handbrake shoes through a hole in the disc drum. Old tech, but easy, unlike the handbrake module to operate the cables.
4,285
I could have worded it better: When in the "Park" position the clutch is disengaged (which allows the engine to be started etc), but at the same time the gear box is mechanically locked so the output drive shafts cannot be rotated.
Apr 23, 2024
434
360
935
For me it’s into neutral and hand brake on. Putting an auto box into park is risking a destroyed box if you are unfortunate enough to be rear ended.
A broken gearbox would be the least of my concerns if I got rear ended , when THO got rear ended whilst broken down it was three weeks in a coma after removal of a subdural hematoma, car declared a write off ( it started out as a corsa and ended up as a nova!!)
3,460
I guess my Tucson must be the same, very old technology that.
If it ain't broke, don't fix it - drum brakes work just fine for parking brakes, they don't get hot in use so don't need the better heat dissipation of disc brakes.
But using the rear disc brake as the parking brake is old technology in itself - my 1967 Fiat 124 had a parking brake that operated on the underside of the rear disc brake piston within the caliper.
5,168
With the old Landrovers the handbrake clamped onto the half shaft. Replacing half shafts was good for business!
May 10, 2020
318
219
10,935
And when you pulled on the hand brake while still moving it was a case of “Everyone down the front!!!😆😆
Devonisheaven
BANNED
Aug 18, 2024
326
214
935
Most certainly did Roger, other manufacturers, especially Italian, adopted the same. It was an absolute nightmare!
