damp meters
Oct 17, 2016
went to change our caravan when the dealers tested for damp it was all over the van. I have a damp meter myself and used to test for damp every 3 months . what a waste of money they are tested with my meter and it was 7 when it was tested with a proper one it was 51 the dealer pointed to spots on caravan and said test there with yours I tested and it was ok when I then checked the wall it felt like a sponge beware when testing with a cheap meter as they are no good I paid £35 for mine what a waste of money
Sep 29, 2016
1,799
210
Sorry to hear that Tony, and after you taking what you thought were all reasonable precautions, is it possible your meter was faulty or needed recalibrating.
I have no experience of damp meter qualityreliability etc.
Does anyone have recommendations for a reliable damp meter ?
Thanks.
Anseo
40
I'm afraid 'reliable' damp meter is almost a contradiction in terms as so much depends on how it was calibrated and how it is used..
Prof John will doubtless give you chapter and verse, but at the end of the day the only relable way is to take a sample of the suspect material, weigh it very accurately, dry it carefully under controlled conditions and then weigh it again. Moisture content is then the percentage loss in weight.
This is clearly not possible with caravans.?
.Some moisture meters rely on a reading between two pointed probes pushed into the material. If before testing you wipe the material with a damp rag wet with either just water or a salt solution to moisten it, the surface moisture may 'short' the mayerial reading and produce a higher value than actually exists. Some basic meters 'polarise' after a few seconds although this is less obvious with more modern meters which apply ac rather than just dc voltage.
I am deeply suspicious of all dealer and consumer level 'moisture' meters and would at least demand to see a recent calibration certificate from a recognised calibration authority before paying any regard to the meter a dealer may use.
3,586
1,799
210
chrisn7 said:
I have to disagree with Ray. I have one of these 4 prong devices. Yes its as cheap as chips, but it works. When buying my van I compared its readings to those by my inspection engineer and they were within 1 % of his pro kit. Its well made of sturdy plastics too.
]http://www.ebay.co.uk/itm/CE-APPROVED-4-PIN-DIGITAL-MOISTURE-METER-DAMP-DETECTOR-TESTER-12-MONTHS-WARRANTY-/291181849456?hash=item43cbca6b70:g:CzAAAOSw7I5TtBNE
http://www.ebay.co.uk/itm/CE-APPROV...hash=item43cbca6b70:g:CzAAAOSw7I5TtBNE[/quote
No eBay APP ID défined in Kunena configuration
This what your post displays, no link to ebay, but when I opened the reply with quote window, your ebay link appears there.
I've had this before when posting an ebay link, no idea as to why it appears, one for the mods maybe.
Here is the link: http://www.ebay.co.uk/itm/CE-APPROVED-4-PIN-DIGITAL-MOISTURE-METER-DAMP-DETECTOR-TESTER-12-MONTHS-WARRANTY-/291181849456?hash=item43cbca6b70:g:CzAAAOSw7I5TtBNE
Tried to add the ebay link but it won't show here :(
Anyone using infrared inspection? It seems to me to be a reliable method to evaluate damp in a caravan, I would surely ask and expert like this one to inspect my caravan:
http://www.immo-check.ca/rv-inspection
The camera can be bought on Amazon for example, prices are in CDN Dollars, divide roughly by 2 to get it in UKP.
https://www.amazon.ca/s/?ie=UTF8&keywords=thermal imager&tag=googcana-20&index=aps&hvadid=145158159790&hvpos=1o2&hvnetw=g&hvrand=3815467624399158845&hvpone=&hvptwo=&hvqmt=b&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9000230&hvtargid=kwd-16227291&ref=pd_sl_8yek81a72s_b
3,134
A company from Canada recently managed to get a post up on the forum, but becasue it was advertising it was quickly taken down, but not before I had the opportunity to look at it.
The company were suggesting that water ingress problems could be detected by using an infrared thermal; imaging camera. It was designed for buildings, but they were suggesting it was also appropriate for RV's. and it was depicted as looking at the outside of an RV.
Its my opinion that based on the fact that TIC (Thermal imaging Camera's) which display a colour picture where the hue is analogous to the temperature of the object or surface, if the damp patch were the same temperature are the rest of the surrounding material, then it would not show up as being different.
However if a wall was damp and the caravans was being heated up, the dampness in the wall would not heat up so quickly and thus it would appear to be cooler, BUT there are so many other reasons why certain parts of a perfectly dry caravan would heat up less quickly, for example most heating systems cannot raise the ensure inside of a caravan perfectly evenly. There could be a frame or another piece of furniture or soft furnishing that keeps part of an exterior wall less accessible to the effect of internal heating.
Also the trend towards wall constructions where there are no wood frames or the insulations is non absorbent would prevent any moisture present from significantly causing localised temperature difference.
As with the more conventional moisture meters being discussed in this thread, it would require careful usage, and a competent user who knows how to read the systems output and allow for both environmental and constructional differences to interpret the presence or other wise of worrying levels of damp.
So I think at best the IR camera would be very poor identifier of damp areas, and it certainly wouldn't show where the source of a leak was. And at worst it would be quite expensive toy with limited applications.
1,793
I have a cheap meter and it does work but at the end of the day you get what you pay for and some of the cheap ones do seem to be a problem. I do sometimes wonder about the damp readings dealers find when doing them but in this case if the wall was spongy it seems clear there was a problem. I do wonder if some dealers find it to adjust the deal agreed which is why I would never take a caravan in for part exchange without having it checked first.
I have have been able to get damp results in the bathroom which was in fact condensation and window frames which was the same so do check out anyone finding them there.
2,399
charlevoix418 said:
And how about those moisture meters used by marine surveyors?
https://www.tramexmeters.com/skipper-plus-mowhatisture-meter-for-boats
After some email correspondence involving the person concerned, Lizzie Pope and myself the person assured us that he is not a company but a private individual who is building a caravan to British spec, and he agreed to alter his profile and forum username to 'charlevoix418' after his first two posts were reported as spam.
Charlevoix,the link to the expensive marine damp meter is not really relevant to a touring caravan forum, and when a new forum member adds these commercial links to their first forum comments it's little wonder that reports are sent by loyal forum members for moderators to take a look. Please consider carefully before submitting any url's for commercial products, they are unnecessary and could lead to posts being removed.
2,894
I have the same one as Dusty Dog, and it reads the same as the mobile fitters proffesional one, very good product.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
dewfewtg
