Dangerous outfit
Page 5 - Passionate about caravans & motorhome? Join our community to share that passion with a global audience!
Dec 16, 2003
2,893
Having had car, bike, truck accidents and race accidents and problems when towing caravans and trailers....
Not surprising really as you don't know when to stop.
This is getting SO boring.
IMHO
Brian (",)
May 12, 2006
2,060
Brian you get 10/10 that really made me smile.
On a rather more serious point, this thread could be giving some people the jitters. Opinions differ to such an extent that I don't understand anymore what a dangerous outfit is.What I do know is that the makers of caravans should spend more money on research to make surs none of us drive dangerous outfits.
Val & Frank
I also thought Brian's comment was amusing Frank. As regards confusion over dangerous outfits if you follow the basic principles which are well documented by both major clubs towing should always be safe and pleasurable. Regardless of what you tow or how many axles it has.
Simple solution: "Driver Training" It should be made compulsory for all drivers to undergo suitable technical & practical training, followed by an appropriate test, and that entitlement added to there licence before they are allowed to tow unaccompanied on a public highway.
Allan.
Dec 16, 2003
2,893
It's a bit like the "safe" claims from the likes of Volvo and Merc and people.
No one is saying that one is very dangerous!
But there are factors that ca make certain stules of van safer when things go wrong.
An air bag in a car is pretty dam useless piece of kit util you bang into something after all. Or split car braking system until one part fails.
May 12, 2006
2,060
ris "I'm not prepared to comment Seth, as I don't have a piece of paper from a scientist or the like "
Remember Y2K don't believe what Scientists tell you, Air traffic control across the world may shut down was one, and hospitals will lose all power was another.
Val & Frank
875
The whole discussion about single vs. twin axles seems to me to be reminiscent of a similar one back in the 70's when experts argued over whether twin engined commercial airliners should be allowed on transatlantic flights or whether, for safety reasons, one shouldn't stay with four engined 707's and the like on such routes.
Dec 16, 2003
2,893
I think you'll find that 4 engine commercial aircraft fly long haul and can continue to destination on 3.
3 Engines have to divert with a failure and 2 engine aircraft only fly long haul on routes where they are within 3 hours of an airport they can land as they must divert when an engine fails. Well that's what my pilot friend has just told me.
Of course a twin wheel caravan can't really go any where with one tyre failure ;-)
875
Can't argue with that although it does seem rather odd that the technical conditions which must be fulfilled to be allowed to tow a 100% weight ratio outfit at speeds over 80kph (50mph) in Germany include ABS on the towcar, a stabiliser and hydraulic suspension dampers on the caravan but no word of twin axles.
Dec 16, 2003
2,893
Well no doubt your laws pander to your countries own
products :)
No doubt the shock absorbers are a step to combat the instability of your large single axle caravans compared the popular more stable British twins ;-)
My understanding is that if you take similar sized vehicles of the same weight but one has more weight nearer to the ground than the other that gives it a lower C of G and adds to stability. That being the reason for race car engineers to get weight nearer to the ground to aid cornering and reduce Centifugal forces that in turn reduce corner roll.
Caravans that have rooves that can be walked on and roof rack provisions seem to me to go against ideal stability as I would guess there is quite a bit of weight high up to give that strength.
4,133
products :)
Hello cris,
The centifical force is generated by turning of the mass. If the cog is lowered the force remains the same but its point of action is lower, and so the leverage it exerts on the suspension is reduced.
Dec 16, 2003
2,893
products :)
Nice fancy way of putting it, to a simpleton like me that translates as low weight = better stability ;-)
In essence it's why we find carrying within the car is better than on top as you get less roll effect that way :)
875
products :)
Shock absorbers are a good deal cheaper and more lightweight than a second axle :)
Dec 16, 2003
2,893
products :)
No real benefit re low down weight and C of G benefits though. And both my T/A vans were fitted with Alko shocks and when we get another so will that be :)
875
products :)
Can't see how an inch or two lower C of G using smaller wheels on a twin axle is going make that much difference considering what heavy junk some people put in their overhead lockers.
Dec 16, 2003
2,893
products :)
No doubt many of us are as good as you at keeping carried heavy goods low down Lutz or even better may be!
I think you'll find that the heavier 2nd axle and wheels etc will move the C of G more than you may think ;-)
875
products :)
Oh, so all that deadweight of a second axle is only to lower the C of G. Now I understand.
875
products :)
Sorry, I couldn't resist that comment. Don't take it too seriously. :)
875
products :)
I still think you're overrating the importance of C of G height on a caravan though. Caravans are not F1 machinery and don't go through corners quite as quickly. If a low C of G were so decisive, there wouldn't be any roof mounted air conditioning units on the market (not that I'm in favour of them).
Dec 16, 2003
2,893
products :)
Better Alive rather than being DEAD WEIGHT yourself as you have the higher C og G less tyre Grip and worse stability with the S/A ;-)
875
products :)
Better dead than alive. Couldn't agree more. However, very, very few accidents involving caravans are actually fatal (in 40 years of motoring I have yet to see one). Most appear more spectacular than they are because of extensive property damage but as there are no occupants inside the caravan and caravans usually distintegrate on impact, they aren't usually a serious hazard to injury for following vehicles, either.
875
products :)
I did mean better alive than dead. That was a typo error.
875
products :)
Just had second thought about this C of G thingy. If you have a twin axle with a MIRO of, say, 1550kg and an MTPLM of 1800kg, you've got 250kg of payload that you should, ideally have low down on the floor. If you have a single axle, also with an MTPLM of 1800kg but a MIRO of 1500kg, you've got 300kg that you can place on the floor, so the net result is the same. The advantage, if any, would therefore only exist if the caravan is not fully laden.
