Decisions!
4,935
Our 1996 Corolla requires a replacement rear box on the exhaust at a cost of nearly £400 for the box plus labour. It is mainly used as a runabout to go into town. The car now sells for more than what we paid for it s/h in 2012 as similar models selling for neatly £1000. It is very reliable and we have spent very little on it except for a rear box several years ago, battery and tyres. OH has suggested selling it and buying another car, but then you never know what you will get buying second hand. I think I would rather pay to have the rear box replaced.
May 18, 2006
590
18,885
If the Corolla has been reliable I would keep it and just get the rear box replaced - but £400 seems a bit expensive, wonder if it's the age of the car and lack of spares?
Reactions: GaryB
8,512
I would have the box changed. As you say buying another runabout is a risk even if you shell out a few thousand pounds. Then when you do decide to sell the Corolla its classic status will be well established and buyers will be fighting to buy it. 😂
Reactions: GaryB and Buckman
4,935
Yep you hit the nail on the head. It also needs rear shock absorbers and apparently they are nearly £200 each however we can live with that as it is not a MOT fail. The car has done 122500 miles of which we have done about 30000 over the past 12 years.
Reactions: GaryB
4,140
Without knowing how much you're prepared to pay for a new- (second hand) car its difficult to rationalise the variables, but if you were only going to try to exchange the value of the corolla, then its better the devil you know.
Reactions: Buckman and GaryB
Jan 20, 2023
1,271
1,114
2,435
I know Toyotas aren’t as well supported by the aftermarket parts supply as other models but as the others said, if it’s dependable, keep it. It’s basic spec will help with it’s reliability!
574
461
1,135
You haven't given the full spec so it's possible £400 is the right price, but it only took a couple of minutes to find this. Add an hours labour to fit it and you should be looking at £150.
4,966
Big difference so maybe I misunderstood and it was £200 for both sides. Can it be a DIY job as maybe grandson could fit them for us?
With the right tools and knowledge it is a diy job. Beware using spring compressor is not something for a first timer without proper instruction. Why not get a few local quotes for Labour or try a mobile mechanic?
4,140
Ask your grandson if he thinks he's able and competent to do it. With some vehicles changing dampers is relatively straightforward, but I don't know the Corolla. And as Dusty says you may need special tools.
8,512
My Forester had both rear dampers ( coil over units) replaced for a Labour charge of £65 at a nearby garage. I supplied the units.
4,935
Thanks I will find someone to fit them shocks. In the meantime I dug out the original quote which was for just under £400 for two shocks plus labour. Online I can buy two Monroe shocks for under £90 so not sure why National wanted to charge about £400! I think Monroe are a reputable brand?
8,512
Monroe are a well established brand so for the Corolla would be fine.
4,935
Had the exhaust done this morning and in addition to the rear box it also required a new gasket further forward towards the engine. Super quiet now and seems to have more oomph?
Local garage has quoted about £100 for fitting the two shock absorbers. About 2 years ago I was advised that only one actually needs replacing, but thought I might as well have both done as A roads around us are very bumpy.
8,512
How much in total did the exhaust cost?
When my Subaru broke a rear spring on its OSR coil over unit one option was just to replace that unit. But after 50000 miles the other coil over would have been subject to wear and tear. So I had both replaced and the ride height came up 12mm. I don’t think I’d ever have just a single unit changed.
4,935
Apparently they are still the original shocks at 123000 miles?
Oct 19, 2023
574
461
1,135
It varies from car to car. Changing the front coils on a Mondeo with a friend took us around 6 hours. When the rears needed doing my local garage quoted £100 each (around £40 labour if I remember correctly), I didn't think twice about giving them the job.
4,935
I watched a Youtube on changing rear shocks on the Corolla and it was fairly straight forward. The local garage have quoted between £100 - £120 to change them if I supply the parts.
Oct 24, 2007
199
Was it a main dealer quoting £400? A quick google seems to think it should be about a third of that price
