- Jun 16, 2005
- 2
- 0
- 0
I have delamination near the kitchen sink,caused i assume because it is a heavy used area. Is delamination a problem or is it just a cosmetic problem?
to finish sandwiching polysterene all bonded together in a press, which provides a very strong but lightweight panel,delamination of this type of floor usally occurs when the bonding fails in a smaal area and if not treated spreads and compounds the problem.Clive, I know what the differance is between a bonded floor and a traditional floor is in caravan trade, traditioal floor is simply an area made up of sheets ply laid across a chassis (as in older caravans) a bonded floor consists of two sheets of thin ply san
CliveSorry guys we are slipping into the world of fantasy here!
It is the original bonding of the laminated multyply wood that fails in a De-laminated floor - Hence the descriptive name???
Your cars windscreen is a laminated structure of glass and plastic to prevent shattering. Marine Ply (very close to what is used on caravan floors) is imensly stong because the various layers of wood ply are bonded together with the grain running in alternate directions.
What do you think a bonded floor is made of? (I ask of GW Metcalfe)
A caravans floor is made of a multiply stucture but over time the bond between the various layers of ply break down due to water ingress or wear. So my floor is a "bonded" floor as I understand all are.
The repair kits consist of an epoxy resin (stronger than what was available in years past) which you inject into predrilled holes so that the resin oozes throught the layers in the ply to appear in adjacent holes. You then plug these holes and move onto the next.
When the resin sets the laminated multiply structure is reformed and the repaired floor is probabaly stronger than when it was first produces thanks to the development of the epoxy resins rather than the glues that were used in the past.
This repair was coverred in one of the mags a litle while ago
Get a grip guys!!
Thanks everyone.The area has spread but it doesnt appear to have spread width wise (i.e.)underneath sink & wardrobe am gonna try Tradeweld Floor kit from The Glue People in Wimbourne as van is 1990 Swift Challenger & not worth spending too much onHi Tim,
I've just bought my first van and like you I am where you were originally. The seller discovered last year that he had some delamination problem in part of the floor of the van. He had it repaired in the modern traditional way. The overall condition of the van to my(unknowledgeable eye) is very good and it is certainly dry throughout. But until after buying it I was unaware that the delamination problem can be caused by water ingress, instead believing that it was wear on the floor.
As soon as i can I intend to have it serviced to satisfy myself that everything is in order. I just hope I have'nt bought a pup.
If I have it will be an expensive experience.
Regards, Tony.
