Dometic fridge error, going away tomorrow, help!
Have a Dometic RMS10.5XS fridge, going away in the morning so just tried to turn it on. On every power source it just reverts back to the error triangle and beeps. Have tried playing with it for a couple of hours with no luck, any suggestions gratefully received!
Try unplugging it for , say 30 seconds then switching it on.Sometimes microprocessor run equipment gets itself into a loop it can't get out of,the processor doesn't know what to do and therefore shuts down.
This doesn't work all the time,but it'd worth trying
On the RM8xxx series if you select Electric and the triangle starts flashing you can still see the power source that you selected. Have you tried selecting gas to see if the triangle still flashes? As the fridge should still be under warranty, get in touch with the dealer.
Try pressing the on off switch until you hear a single bleep (about two-three seconds) then let go (if the unit turns off you have held the button in for to long, start again) this should clear/reset the fridge.
