EHU 2.5mm flex
4,021
1,761
Some tenters take fan heaters, microwave and a beer fridge - so yes, quite possible.
Possible does not equate to my stated "typically".
Of course tenters can opt to carry loads of high power consuming kit, but I suggest more typically they don't. Be this wanting to keep weight down, bulk down, camping investment down or selecting to do their camping in the warmer seasons.
Oct 19, 2023
618
487
1,135
"Artic "cable, unless this description is not a definitive product seems still to feature PVC insulation & sheath.
Indeed it does however that stuff is only used on lorries ;)
Arctic grade cable is also PVC but a different formulation to HO5VV-F to allow it to remain flexible at lower temperatures. It is also more durable and has a thicker sheath, hence it's use on building sites where it's likely to be abused. It is defined in BS EN 50265 and BS6004.
9,034
It's possible to buy distribution units with a 16A plug, RCD and several 3-pin 13A sockets.
I used a Maypole 4 outlet unit. With 13 amp sockets, protection and USB outlets. Each socket had a splash proof cover. The cable length was 15m. I would hang it in the tent. But I’ve absolutely no idea what the cable specification was, and to be honest it didn’t bother me.
618
487
1,135
For use in a tent it's also possible to buy something much more suitable than a lead with a 16 amp plug on one end and a 16 amp socket on the other.
9,034
That’s almost the same as I used, except mine was 15m cable length.
Reactions: Beardy
4,021
1,761
I recall there were also somewhat lumpier ones with an integrated RCD and these featured a hook for suspending it vertically and off the ground.
Reactions: Beardy
9,034
You are correct. This is the type I used by Maypole. It could be hung above the ground.
5,225
I thought your first link was an early April Fool🙃
Why on earth would a Caravan Accessory shop sell a NCC non approved EHU cable🙉
Which brings up the question of how does the NCC go about approving the cable as they do not have the authority or probably the facilities for testing the cable? Probably just a tick box exercise?
4,021
1,761
Like the NCC rating of leisure batteries, it's all about marketing not technical safety.
Which is so very sad and misleading as those who don't understand how it works can readily believe it brings some authoritative credence to their listings.
