EHU 2.5mm flex
Some tenters take fan heaters, microwave and a beer fridge - so yes, quite possible.
Possible does not equate to my stated "typically".
Of course tenters can opt to carry loads of high power consuming kit, but I suggest more typically they don't. Be this wanting to keep weight down, bulk down, camping investment down or selecting to do their camping in the warmer seasons.
"Artic "cable, unless this description is not a definitive product seems still to feature PVC insulation & sheath.
Indeed it does however that stuff is only used on lorries 😉
Arctic grade cable is also PVC but a different formulation to HO5VV-F to allow it to remain flexible at lower temperatures. It is also more durable and has a thicker sheath, hence it's use on building sites where it's likely to be abused. It is defined in BS EN 50265 and BS6004.
It's possible to buy distribution units with a 16A plug, RCD and several 3-pin 13A sockets.
I used a Maypole 4 outlet unit. With 13 amp sockets, protection and USB outlets. Each socket had a splash proof cover. The cable length was 15m. I would hang it in the tent. But I’ve absolutely no idea what the cable specification was, and to be honest it didn’t bother me.
For use in a tent it's also possible to buy something much more suitable than a lead with a 16 amp plug on one end and a 16 amp socket on the other.
I recall there were also somewhat lumpier ones with an integrated RCD and these featured a hook for suspending it vertically and off the ground.
You are correct. This is the type I used by Maypole. It could be hung above the ground.
Anyone considering buying 2.5mm yellow flex may be wise to try and find a local electrical supplies retailer,it could well be cheaper.
For the past several years we have been using our old caravan EHU for a electric supply to the shed at the bottom of the garden. Cable is now a yellow colour, but still looks to be good considering it is exposed to the elements 24/7 365 days a year. When in use, it does not carry a heavy load mainly for lights in the shed or charging a 12v 90ah leisure battery.
If the outer cover of a cable changes colour (presumably due to day and sun light) iy should raise a concern even if its is only loaded lightly. If the insulation has changed colour its possible its insulation resistance may have also deteriorated, and does not affect its current carrying capacity, but it will affect its insulation resistance, which means it could become "leaky" under high voltage. It's certainly worth having checked for IR and any signs of of the PVC breaking down.
Thanks. To be honest for the past couple of months I have been considering changing it, but just did not get around to it and hold my hands up due to procrastination.
